Since i was free yesterday, i decided to clean my car & prepare it for the rainy days ahead.
It took me about 4 hours to vacuum the interior, bathe and dry it, & finally to wax the thing. In between syempre may meryenda at konting chat on the side [emoji16]
I guess its really 2 hours standard for 2 bucket/shampoo/dry/pressure wash.
Here's my routine:
1) Pressure wash first to wet the car
2) Foaming (lance), wait for 5 mins for it to work on the dirt and grime
3) Pressure wash to rinse
4) 1 bucket with car shampoo. I use 5 wash mitts. 1 mitt per area of the car.
5) Pressure wash to rinse
6) Pat dry the whole car with a large MF towel
7) Leaf blower for every nook and cranny
8) Ultimate Quik Detailer
Done in 2 1/2 hours. Was 3 hours before when I used the 2 bucket method with grit guard.
Looking to reduce the time. Maybe, I could skip 2 and 3 and go straight to 4 if the car is not that dirty. I could also use another large MF towel for drying.
Let see if I could get this under 2hrs.
You could try the flooding method to dry the car. Pressure wash rinsing leaves a lot of droplets on the horizontal surfaces. Might save a bit of time in the drying phase.
For pre-wash soaking, I just go straight to foam, then rinse with pressure washer. That would eliminate 1 more step from your process.
But really, the best time-saver for me is rinseless washing (if the car isn't too dirty).
Bat prang ang hrap magpatuyo ng elite ng microtex? Yung waffle weave. Mas ok pa png dry ung plush or ultraplush
^not following instructions yata kayo bro ^_^
sabagay nung una, hirap din ako, need pa 1 microfibre towel para matuyo yung ibang parts. after couple of use, OK nasanay na![]()
Is it better to apply quick deatiler on my daily driver weekly compared to applying two to one coats of collinite weekly?
I'm gettinf the hang of using the quick detailer hehe
Sent from my SM-A700FD using Tapatalk
Wala ata connection if coated or not.
Try mo din buhusan ng tubig imbis spray/hose before drying it up. Para less yung big water pools.
Open mo din hood/trunk/doors para tumulo kahit papano.
It will still leave water streaks, pero ako hinahayaan ko na lang. Nag eevaporate naman din hehe.
Balak ko naman every year pa detail, so I'm just trying to do my best to minimize swirls and fine scratches.
At the end of day, we're just delaying the inevitable hehe.
