Page 350 of 392 FirstFirst ... 250300340346347348349350351352353354360 ... LastLast
Results 6,981 to 7,000 of 7833
    #6982
    Quote Originally Posted by zero3 View Post
    Planning to buy a polisher. Looking sa dewalt 849x. Ok ba sya? Anyone using it here? Saka advisable mag polisher every other week for applying spray wax or carnauba? malakas ba sa kuryente? Sensya na daming tanong.
    Sent from my SM-T705 using Tapatalk
    If you do not have experience in polishing i wont recommend getting a rotary polisher. A rotary polisher is a very powerful machine and poses a high risk of damaging paint if not used properly. A dual action polisher is a better and safer choice.
    Sent from my SM-G965F using Tapatalk
    #6983
    Quote Originally Posted by Ginnova View Post
    Does this statement apply to ShineMate EP802 Rotary Polisher?
    #6984
    Ep802 is one of big rotary polishers in Shinemate lineup. Its the most powerful * 1050w. This polisher is designed for bodyshop use. See photo comparing shinemate polishers. The small one is their mini rotary. This what i mainly use for tight areas and paint jewelling.
    #6985
    Ok, but you said "a rotary polisher is a very powerful machine and poses a high risk of damaging paint if not used properly. A dual action polisher is a better and safer choice"
    So what model of dual action polisher do you recommend?
    #6986
    Any decent DA should be fine . Porter Cable, Griots etc but these are mostly 110v.
    Your next option is Shinemate. These are 220v and has local warranty.
    The Shinemate EX series polishers are excellent. They are based on the Rupes bigfoot platform.
    If you budget is not an issue , Rupes is the way to go.
    PM me or visit my website if you are interested.
    Feb 2010
    #6987
    Is shinemate the brand carried by microtex? Not sure if this was the same rotary polisher i saw displayed in their booth at the recent auto show * World Trade Center
    Oct 2003
    #6988
    Ung porter cable ok for beginners. I have the gen 1. Ergonomicsnis not so great pero nasanay na din. Looking for a better upgrade next time siguro.
    #6989
    Quote Originally Posted by zechs View Post
    Are you referring to the Griots Garage 6 Inch Random Orbital Polisher porter cable and if it is why not so great?
    I'm looking for car polisher na pang-compound, polish, wax and buff and also can remove scratches and swirl marks.
    Gawin ko ring pangtanggal ng over spray na natira, nung magpa-repaint ako.
    What do you have in mind for your upgrade?
    TIA
    Dec 2018
    #6990
    Well, you can use naman ung foam gun that runs from the hose lang. Pero need pa rin na mas malakas ung water pressure nyo sa bahay.
    Actually dati gawa ko is, gagawa ako ng wash bucket and then iyon ang ibubuhos ko initially sa kotse since wala pa akong foam gun or foam cannon. Hehe that works too pero syempre mabilis din mag-run down ung soapy water.
    Hi sir, same concern. Malakas naman pressure ng water dito sa bahay. Question lang po. San nkakabili ng ganyan foam gun. Thanks.
    Sent from my SM-J730G using Tapatalk
    Oct 2003
    #6991
    TIA
    Porter Cable is a different brand from Griots Garage. Mataba kasi ung handle ng PC eh. So medyo cumbersome.
    Looking to purchase ung Shinemate EX610. I think they patterned it after Ruper LHR MK 2.
    Nov 2011
    #6992
    I applied a Meguiar's Ultimate Liquid Wax right after a Carnauba Cleaner Wax, okay lang ba yun? Hahaha.
    Then monthly re-apply the ULW then occasionally yung cleaner wax.
    #6993
    Quote Originally Posted by TheUninvited View Post
    kung spray wax bro, may solvent yun so matatanggal carnauba konti, but it should be fine. kung liquid wax lang na applied thru pad , OK lang
    Nov 2017
    #6994
    Anyone here knows where I can buy this excellent plastic trim restorer locally? Medyo urgent, ordering it overseas is currently not an option [emoji53]
    Solution Finish - Trim Restorer
    How To - Best Plastic Car Trim Restoration - YouTube
    #6995
    Try Richard Lin's Black Wow. I know overseas isn't an option, just throwing this good product on here.....
    BlackWow Trim Restorers
    https://www.amazon.com/Black-Wow-BW04-4oz/dp/B00144FZUG
    Black Wow Application Video - YouTube
    Nov 2017
    #6996
    Finally found a local seller:
    Solution Finish Black Trim Restorer - REFLECTIONS CAR CARE
    #6997
    Will ship out your order today.
    Ensure to prep/clean surface before applying. Thin applications is recommended. Then apply another layer once last layer is dry.
    Another option is gtechniq c4 permanent trim coating
    sir meron ka na SiO2 products?
    Nov 2017
    #6999
    Thanks sir!
    May 2005
    #7000
    where do you buy optimum car wax?
"Tamang OC lang" - a newbie's guide to car appearance maintenance
