Page 330 of 392 FirstFirst ... 230280320326327328329330331332333334340380 ... LastLast
Results 6,581 to 6,600 of 7833
    Quote Originally Posted by xnxnxn View Post
    Whew been doing that routine for a month now kaso magastos pag araw2 iispray ng qd o i wwash.
    buy a gallon of rinseless concentrate
    Mar 2017
    #6582
    ^ This. You can dilute it as a wash, or as a QD. Either way, it's very economical, especially compared to off-the-shelf QDs.
    Jan 2008
    #6583
    Quote Originally Posted by rhOvEn View Post
    Dry wipe/wiping your car's paint even if its coated (glass coated) will cause damage to the coat. Any coat paint protections has it limits, this coat acts as a layer of your car paints protection and in time it will wornout. The dirt interacts with your car's paint, when you touch the paint without lubrication.. any micro-pebbles present will cause teeny-tiny scratches which can mangle the glass coat or the clearcoat. Ask your glass coat installer on how to maintain & keep intact the protection of your glass coat.
    kaya much better pa din to wipe it wet with shampoo para madulas. i bought a Ryobi blower.. to blow dust off my car prior rinsing with water to remove any dirt remaining then wipe softly with wet wash mitt. blower is also good alternative for using duster.. less contact on the paint surface
    i also use turtle wax and dry to for easy drying and minimize repetitive wiping of micro fiber cloth. i also recommend yung member's selection micro fiber plush cloth sa SNR * 999/pack (24pcs) pero 499 lang pag sale. very soft and good for absorbing water.
    Nov 2017
    #6584
    Sir, may I know where I can buy this Ryobi blower? This blower can perhaps be used for removing water deposits from the car's window panels and areas after a car wash.
    May 2017
    #6585
    I use California car duster or the local version Microtex. It has paraffin wax. It won’t cause swirls or scratches if you use it gently and just glide it on top of the paint barely putting any pressure.
    Sep 2006
    #6586
    Quote Originally Posted by Shutterbug View Post
    +1 to this, I use Microtex. Just don't use it on direct sunlight or when car's surface is hot.
    how long before the duster becomes abrasive?
    Apr 2018
    #6588
    Hi, I'm a newbie here. I know that microtex nanosliq is a good QD, though one of its issues is streaking. I searched microtex's website for an alternative product and found two more QDs, namely, after wash and quick shine. I've searched this thread for these two products but it seemed that nobody mentioned it. Is anybody here already tried those products? What do you think about it? thanks.
    I apologize if this is not the right thread to ask this question. Thanks.
    Mar 2016
    #6589
    Quote Originally Posted by M3ROI View Post
    Hi BRO, welcome to the addicting world of detailing.. “TAMANG-OC”.
    Let me share to you some detailing insights that I’ve learned not just from self-experience but most of all from the detailing-Gurus whom made this thread.
    The Microtex MTX NanoSliq (new name of Microtex NanoSliq), this QD is both beneficial as a CLEANER QD and a WAX BOOSTER QD. The issues of streaks in this QD has tackled down by the detailing-gurus if you back-read. Anyways as I recall, to prevent streaking to the cars paint these will do:
     Spray per panel only... not the whole car panel, use only a small amount of the product like a mist or few squirts will do then wipe-on and wipe-off with a microfiber cloth.
     Spray the QD to a MF cloth or into a wax applicator then gently apply and spread per panel, use an extra MF cloth to wipe-off/buff the QD residue.
     Mixed it to a DISTILLED H20 with a ratio of 1:1, doing this will lessen the effect of streaks. Also a economical cost approach.
    The Mictrotex MTX After Wash, a new car care solutions product line-up of Microtex. As product stated, “Use After Wash every time you wash your car to keep your car looking new. And in between waxing to maintain that slick smooth feel and deep wet-look shine you can only get from regular waxing.” IMO the product serves as a drying aid solution. It’ll make the car paint drying process fast and safe from potential paint defects like; water-marks, etch, swirls, etc. It acts as lubricant between the car paint and the drying tools to be used such as MF towel and/or Waffle Weave Towel.
    Either spray it all over the panel then wipe-on / wipe-off with MF towels (IT WILL NOT STREAKS.. JUST DON’T APPLY UNDER DIRECT SUNLIGHT). And/or spray into the MF cloth and gently apply/glide over each panel follow with extra MF cloth and buff to remove excess.
    The Microtex MTX Quick Shine is also a new care solution product by Microtex. This is a SPRAY WAX the fastest way to instantly give your car that freshly detailed image. As the product speak to itself, a READY TO GO WAX. Just like other competitor spray waxes, IMO.. Quick Shine contains cleaning agents, will clean/remove light dust/dirt and hides some minor paint defects. As for application of this product, either spray-mist directly to the car paint and/or spray into the MF cloth WOWO (Wipe-On/Wipe-Off).. no more wait to dry nor curing time. It will cause STREAKS if not wipe-off quickly. Longevity of its shine and protection as observed if drive daily and park at covered/shaded area, will take a week or two.
    I hope these inputs may help you about the products. I may not get into deeper details.. but our detailing GURUS are there to give you much better answer regarding these.
    Sep 2006
    #6590
    Diluting nanosliq with distilled h20? This I didn't know. Thank you!
    Jan 2017
    #6591
    Spray per panel only... not the whole car panel, use only a small amount of the product like a mist or few squirts will do then wipe-on and wipe-off with a microfiber cloth.
    Spray the QD to a MF cloth or into a wax applicator then gently apply and spread per panel, use an extra MF cloth to wipe-off/buff the QD residue.
    Mixed it to a DISTILLED H20 with a ratio of 1:1, doing this will lessen the effect of streaks. Also a economical cost approach.
    How should i use the mtx after wash? I heard waffle weave have hard time drying so should i use it when wiping the car dry?
    Sep 2017
    #6592
    Quote Originally Posted by Kimchijiji View Post
    I suggest you visit youtube And watch videos to learn more. Ammonyc is one channel I recommend. You will learn a lot.
    For after wash I use it as a lubrication to minimize any potential scratching. Dampen your drying towel, wring out and spray after wash on it 2-3 times then wipe the water off gently. I use microtex plush mf as drying towels.
    If find it streaks too much if I apply it directly but I don't use it as a wax just a lubricant. I just ordered after wash to try btw. My main drying spray is ONR.
    Sep 2006
    #6593
    Once and for all, pwede ba talaga gamitin ang elevo watermark remover sa side mirrors or not. I did a search iba iba opinion. To the sirs and mam who did it, can you share what the outcome was?
    Jan 2017
    #6594
    Quote Originally Posted by MamBad View Post
    So should i spray the drying towel 2-3 times for every panel or its for the whole vehicle already?
    #6595
    Paste version pwede. But liquid version do not use any acid based waterpot remover.
    Sent from my SM-G610Y using Tapatalk
    Sep 2017
    #6596
    When it has absorbed too much water, I wring it out and respray. Small towel so it happens maybe every panel or maybe even less. Depends on how much water you have left to dry on your car. I sheet water first, blower off water in crevices, and lastly wipe off.
    Jan 2017
    #6597
    Is it safe for the paint to do this? Thou i wnt be spraying it directly. Wont it hurt if im soing it everytime im drying my car?
    Sep 2017
    #6598
    You mean application of after wash every time when drying? I don't think it should be a problem since I think this wax isn't made to be durable and should wash off with rain or a car wash. If anything it adds a sacrificial layer. I use mine on top of a sealant glaze btw.
    Also, I don't think too much wax hurts the paint at all, of course laying certain waxes on thick can be a pain in the ass to buff off.
    Jan 2017
    #6599
    Should i dilute the after wash mtx?
    Jan 2012
    #6600
    Discounted Meguiars at Microtex kanina sa MIAS
"Tamang OC lang" - a newbie's guide to car appearance maintenance
