Page 231 of 392 FirstFirst ... 131181221227228229230231232233234235241281331 ... LastLast
Results 4,601 to 4,620 of 7833
    #4601
    Butter wax when wet...sarap gamitin hehehe
    Yup. Smells so good!
    Jul 2015
    #4602
    I've been using 915 for 5 years na. Durability hmmm pano ba. Siguro sa extreme weather conditions dito sa atin tumatagal yun beading for 3-4 weeks.
    Every after wash I spray QD. Pag sinumpong pinapatungan ko ng Megs Deep Crystal Carnauba Wax. Added protection and shine.
    If durability habol mo, maganda 476 talaga. Yun ang tunay na matibay. Tsaka 885 Fleet wax. Kaso wala naman nabibili dito.
    Hmmm, 3-4 weeks? Not bad. Will try the 915 pag naubos ko na yung 845 and 476 ko. Thank you sir.
    Nov 2012
    #4603
    Quote Originally Posted by ivanmarzan View Post
    Mga sir may glass coating services po ba dito saatin sa pina?
    I am interested too
    #4604
    Quote Originally Posted by halowan View Post
    I am interested too
    Sir PM nyo po si sir kitoy22
    Aug 2004
    #4605
    Quote Originally Posted by DarkMatter View Post
    I believe so sir since cleaner waxes usually contain petroleum distillates which are also present in gasoline or kerosene. Thus may strip the wax or sealant present on the paint.
    I use cleaner wax depending on accumulated stains and watermarks on the paint (usually 2-3 times a year) or when i don't have time to clay and polish the car.
    Best to use it after wash or clay and before applying wax/sealant of your choice. HTH.
    thank you very much, sir.
    planning to buy the klasse twins soon.
    Mar 2015
    #4606
    Quote Originally Posted by mcbry View Post
    That would be a better alternative sir. Klasse twins work really well on prepping the paint and protecting it at the same time. After trying it myself and based on the reviews here by fellow tsikoteers. It works like bread and butter. :D
    Sep 2014
    #4607
    Hi Masters,
    I've been lurking this thread for quite sometime now. I am doing a regular wash-wax (Nano Gloss) then maintain it with QD (nanoslig) to my ride following the steps I learned here ever since. Now that my ride is turning 1 year, I am planning to give it an overall spa treatment kumbaga. While I know that it would be better to bring it to professional detailer by now I will need to deffer it due to budget concern.
    I would just like to ask your expert advice regarding my plan of attack sa Spa Treatment ng car ko.
    Step 1: Wash - Microtex Shampoo
    Step 2: Clay - Mothers clay bar w/ showtime as QD followed by wipe down ng alcohol mixed with water. (mas mahal kasi pag showtime ang pang wipe down)
    Step 3: Polish/Compound - Can you suggest a budget friendly polish/compound. Would you also recommend to do compounding then polish or I just need to choose 1? Paint condition is pretty good with minor hairline swirls lang.
    Step 4: Sealant - can you suggest a budget friendly sealant na ok.
    Step 5: Wax - ok na ba yung Turtlewax Ice spray wax?
    Repeat step 5 - every month or as needed
    Repeat Step 1-4 - every 6 months.
    Thanks in advance.
    Quote Originally Posted by iSIDro View Post
    Hi Masters,
    Thanks in advance.
    - never use a compound or abrasive polish. unless its really needed.
    - if you really want to use a sealant(not sure which products are available),I would use a glaze product or polish/glaze product before the sealant.
    - spray waxes are not as durable as paste waxes. but perfectly fine for after-sealant protection. you have to let the sealant cure though.
    Hi Masters,
    Thanks in advance.
    Sep 2014
    #4609
    [QUOTE=StockEngine;2603753]- never use a compound or abrasive polish. unless its really needed.
    Will the sealant do the job in removing swirls?
    For swirls its usually fixed with a polish. I would ask a detailer to do that for me. Meron paint correction options sa TDS the detail studio. Theyll do a better job with their machines.
    Sealants dont have fillers. Some polish products have fillers some dont. Some glaze products also have fillers for swirls.
    Sep 2014
    #4611
    Question lang ulit. Can I use a scratch remover to remove superficial swirls? I have mantis scratch remover that I used to fix dog scratches on my door. It was effective and easy to use. I am curious if I can use this instead of a compound, then top it of with a sealant/wax afterwards.
    TIA
    TIA
    #4612
    ^ compounds use abrasives to diminish the clear coat para i pantay sa lalim ng scratch therefore permanently fixing the scratch but your clear coat is reduced. Then there are those so called fillers which do the opposite, like the mothers step 2 and some waxes, which fill the scratch para pumantay sa clear coat. The latter is temporary fix, pag na wash out na yung fillers kita ulit scratches but the original kapal ng clear coat mo stays. I just dont know which category mantis belongs kasi im not familiar with it.
    #4613
    TIA
    TIA
    Try mo muna yung 3M swirl remover; need patience to do it.
    Kung medyo malalim at mas mabilis na result; 3M scratch remover.
    Pwede ba mantis scratch remover sa dusky brown?
    TIA
    TIA
    #4614
    I am interested too
    Sprint Auto Spa at congressional installs cquartz ceramic coating
    Nov 2012
    #4615
    Quote Originally Posted by Ginnova View Post
    Salamat!
    Salamat!
    Aug 2015
    #4616
    Ano po ba magandang klaseng duster? At most kasi once or twice a week ko lang malilinis sasakyan...
    #4617
    Quote Originally Posted by Dende View Post
    i assumed your car is waxed. california duster gamit ko, works like a charm.
    Aug 2015
    #4618
    Quote Originally Posted by benchman View Post
    Ang alam ko bagong wax lang siya kasi kagagaling lang sa casa, pero naligo na sa ulan eh. May mga nakita akong micro ewan duster sa ace, around 600-700 kaso di ko sure kung ok yun. San nakakabili ng california duster?
    Jun 2004
    #4619
    Microtex duster. Just wrap the duster with a newspaper for a day to absorb the paraffin wax.
    #4620
    sa blade sir. mas mahal nga lang sya sa microtex pero halos pareho lang naman yun dalawa na paraffin wax treated, pili ka na lang kung ano mas preferred mo in size at kapal ng strands sa dalawang brands.
"Tamang OC lang" - a newbie's guide to car appearance maintenance
