Quote Originally Posted by kent1023 View Post
thanks mam madkatz sa reply, actually wala naman siyang swirls may mga hairline scratches lang, kita lang if you look closely... black kasi car ko. if after kong gumamit ng nano gloss, slick or other quick detailer like showtime, wipe & shine...do i have to wash my car again if i want to apply another layer of KSG?
eto ride ko after applying 1 coat of KAIO at 2 coats of KSG with 24hrs curing time in between, just used wipe & shine to prep before KSG.
Hmm if i were you i would just wait for the existing KSG to be spent before i re-apply it again with KAIO and KSG, you see if there's already a wax on the paint KSG won't really bond with the paint properly, so what i would do in your case is after 4 to 5 months i would totally zero out and remove anything on the paint by using a clay if necessary and a pre-wax cleaner or in your case KAIO. The common practice is to layer as much sealant as you want, 2 is good, anything above 3 is already like wasting product except if you have polycharger, and then layer the wax you want, and then use a wax to maintain the current protection and after 4 to 6 months remove everything and re-layer again.
