Page 40 of 127 FirstFirst ... 303637383940414243445090 ... LastLast
Results 781 to 800 of 2535
    #781
    wag mo gamitin tong buwan ng tag ulan
    Jan 2010
    #782
    How do you take good care of your car exterior expecially this rainy season?
    Klasse AIO + SG + SG (yup, 2x) and wash often. Park indoors whenever possible at iwas baha.
    Aug 2010
    #783
    Quote Originally Posted by paolo37 View Post
    yup sir parang libag lang sya.. sir ano yung KAIO? howmuch sya? sa nano gloss kasi 99 pesos yung small bottle.. nawawala naman yung libag nya...
    It isn't practical to buy KAIO just to remove impurities since one "can" would last you 2-3 years. It's pretty pricey though at 2000php. A better option would be to simply avail of your suking detailer's services. This way, you can "clean" the paint every quarterly while you use Nanoglos on a DIY weekly maintenance basis.
    Jan 2012
    #784
    Mga boss recommended niyo ba collinite insulator wax?
    Aug 2010
    #785
    Possibly one of the most sulit 800 pesos you'll ever buy!
    Out of Collinite's lineup, I only use 845 and the Sapphire Wax Cleaner. This is on the basis that the 467, although durable, is hard to remove while the 915's "carnauba" wax usual increase in depth and richness is useless on my white paint.
    Apr 2012
    #786
    Ano po marecommend nyong wax na cheaper sa Collinite, etc? Ask ko na din guys ano magandang pantanggal ng minor scratches? Yung mga scratches is either galing sa car cover or may sumandal sa gilid.
    Jan 2012
    #787
    Quote Originally Posted by jhnkvn View Post
    Salamat boss. Will try to use this insulator wax. Wala kasi kaming garage eh so I thought baka okay to as protection since half lang ng auto ko na-cocover.
    Aug 2010
    #788
    Quote Originally Posted by eminem6480 View Post
    Well, there are quite some waxes out there that are cheaper than Collinite. However, the only one equal sa Collinite when it comes to price-durability (and that's easily purchasable too) is the Klasse Twins combo.
    Removal of minor scratches? Polish. However, scatches will eventually form again after you even them out so it's a fruitless battle. My tip is simply to accumulate them and polish quarterly or something. Also, you may opt to purchase a glaze to "fill" the scratches. My bottle of Microtex Nanosil does this well enough on a hand-basis, results would be fantastic via machine application though! Take note that most waxes "hide" scratches to a certain extent so just the practice of waxing alone might help ;)
    Jan 2012
    #789
    Curious ako sa nanosil eh. I want to buy one pero dont know how to properly use it. Does it com first after you wash the car or after waxing?
    Aug 2010
    #790
    Quote Originally Posted by carwhacko View Post
    Hmm, assuming the typical Collinite regimen, it'll be wash -> Nanosil -> Collinite -> Nanosliq/OCW. Hand-application isn't bad but to get the best out of it you'll need a machine.
    Jan 2012
    #791
    Thanks sir! dame ko na natututunan sayo about sa detailing. Hehehe sana marame pa ko malaman :D
    #792
    HI guys, where can I buy the Klasse combo? I have a hard time looking for it.
    Oct 2008
    #793
    None at Tru Value? There's also the Carlack combo that's the same with Klasse, just in case you chance upon them.
    Dec 2009
    #794
    Sir share ko lang tong ginagawa ko pang tanggal ng "Libag" sa kotse.. ewan ko kung safe pero wala naman me nakikitang negative sa ginagawa ko.. kinukuskos ko kasi sya ng nano gloss para mawala then spray ng nano slic.. eto po pix...
    Yung red Circle yung nagamitan na ng nano glos, then yung blue is yung wala pang nano gloss
    Nano Gloss
    ayan naman po yung nagamitan na ng nano gloss kita nyo naman po ang laki ng nilinis nung may nano gloss na..
    eto namna po yung kabilang side, tapos ko na po sya,, yung kabilang side naman po ang madumi.. umubos po ako ng 1 small bottle ng nano gloss for each side..
    ask ko lang po kung ano maganda pang maintain para sa white color.. ok lang po ba yung nano slick? and yung mura lang po hehe ndi po ako gumastos ng lampas 500 para matanggal yung libag sa suv ko..
    #795
    Quote Originally Posted by indiej View Post
    Thanks a lot. Will try Carlack if Klasse is not available there.
    Aug 2010
    #796
    The thing about Nanoglos is just that just that it has very light cleaners. It doesn't even do even 80% of the job of your typical cleaner. White isn't white "enough" unless you've seen what a dedicated cleaner does.
    If you're cash-strapped for KAIO, go for Collinite's Sapphire Wax. That way it cleans and protects (so it's a 1-step detail) na rin. I'm not sure of the prices though and you'd need a machine for it to work best. Check your suking detailer since William's Bluemile in Gilmore Ave. typically charges me around 800php for Wash + Clay + Sapphire + 845 on a 15% standard discount (pays to have connections :naughty2
    Jun 2007
    #797
    What's a good cleaner wax under P600?
    Oct 2011
    #798
    I think Step 1 of Mothers should be at that price range.
    Oct 2008
    #799
    Mother's/Meguiar's Step 1 are pre-wax cleaners. Hmmm, your post count is ten times mine already. Which section in the forums have you been frequently helping out the tsikoteers?
    Paolo, just to help you out of swirls, keep the detailing tools free from dust/sand/dirt. They're better off on a clean surface/container and not on the floor. The oxidation removal may be attributed to your mf pad and arm power.
    You got a lot of good advice from the previous posts.
    Does anybody know where to source a medium strength clay bar for paolo under 500 PHp?
    Always test the whole process you've formulated on a small area. When you're satisfied with the time and effort used to get your needed results from a particular method, then go for the whole car. SwirlX or the stronger ScratchX by starting out light handed. Don't over exert the rubbing, ever.
    Feb 2012
    #800
    Sir,
    tulong naman paano maalis ang mga water amrks sa car paint meron kasi mga water marks na hindi ko maalis specially sa hood. ano maganda pang alis ng water marks?
Detailing Thread [For Newbies][continued 3]
