Results 181 to 190 of 1418
March 31st, 2007 09:33 PM #181
after reading sir delfin's email invite... here i am, have read few post... galing talaga ng pinoy!
re:ME, got a ME friend that contarcted/restored my '55 benz back early 90's... may sariling bender sa bahay/welding xlt fabricator din nun panahon yun... kaso lang when pinatubo struck san fernando (oct 95)...wala gano customer, hence was force to work as a quality control engineer in 1 of the jap automobile plant in laguna.
chasi manufacturer: sa may valenzuela meron nag fabricate/ dun gawa yun mga XLT/elf/jeep chasi ng pampanga/bulacan... or SPCMMI sa san pablo lag/ sa mga jeepney chasi naman.
pwede din pa custom made ng chasi sa kanila...
may friend din po ako na may CNC laser cutter/ind'l machine press
to potable CNC mill/milling up to 6 axis (can engave/cut metals for emblems/decals) or
related task...can be usefull...
lawin motors po is temporarily closed due to financial problems...
dami po kalaban, subic/cebu imports, xlt fabs in pamp, multi cabs in cebu
korean vans, but its facility is intact... ( pwede po natin pagusapan)
wala lang po time magbasa pa...but i will, sino punta WTC bukas?
March 31st, 2007 09:59 PM #182
years ago sumali din ako sa UV on the spot designing contest sa PICC sponsored then by FMC... counterFX name ng entry ko... its similar to then
anfra transporter but with simplier body lines/curves... sa pampanga pa ako na-uwi then...hindi kuna alam kinahinatnan.
back then HOT sa market ang tamaraw from toyota... sana sinunod nila
trend...ng nagkaroon sana ng FMC-taxis... years later isuzu/mitsu introduce their own variants...
just a note to designers... make the head lamps/tail/signal/clearance lights simplier
square/rectangular even round para mas madali makahanap ng aftermarket
parts yun pobreng may ari...(concept ng owner/jeep) pag kase ala crv/altezza
hirap din pa custom-made fabricate ng ganun from plastic manufacturers kung konti lang...gawa pa sila mould/spl order???
mahirap humanap ng pyesa...pag ala "japon" ganun din... parang XLT ang dating??? sa grill nalang bumawi....dito ang distincion!
April 3rd, 2007 11:14 AM #184
Magandang araw po! Im a new member of tsikot.com and found this thread which interest me. Otherwise, I will share and post my phUV concept here soonest.
Salamat Po!
April 3rd, 2007 11:31 AM #185
April 3rd, 2007 04:32 PM #186
I have sketches. But I have to scan them. But I do have a lot of blueprints myself.
Im working on a van. Probably a LWB and a SWB version (SWB is for the 4WD version) I am also thinking of a very competitive angles.
April 3rd, 2007 05:14 PM #187
the blueprints are very useful for measurement comparisons between what is out there and what we are designing para realistic talaga. does your blueprint have measurements? whats the resolution of those blueprints that you have? mas malaki, mas maganda para madaling sukatin.
- Mar 2007
- 7
April 3rd, 2007 05:59 PM #188Hi guys...! Im also new to this thread and I am glad to see the enthuasiasm in you.. Just want to ask if anybody here resort to making scale model after finishing your designs? I think its a nice idea and cheaper too so that you can actually see how your drawings would look like in the final prototype... Because even the big manufacturers they still do clay modeling before deciding to roll out into final protoype.... Just asking.
April 3rd, 2007 06:03 PM #189
April 4th, 2007 11:10 AM #190
Hi Roman.
Scale modeling is actually the next step to computer 3D modeling.
Small design group lang tayo dito, kaya can't afford full-size (FS) clay or wood models.
The scale model is the bridge between the drawings and the prototype.
So far, we are seriously thinking of building up to the ... < > ... stage.
Meantime, if you're really into this project, read the thread history, drop by often, and if you have other ideas, please don't hesitate to post them. BUT if you want some confidentiality, you can PM architect, OyiL, or myself.
dprox
www.disenyopilipino.ph
You might want to check out the slide show at http://www.disenyopilipino.ph/Chokar...brication.html
Konstruksyon ng Metro Manila Subway Project, ininspeksyon ni PBBM PTV Philippines
Metro Manila Subway 2022/2025
