Results 81 to 85 of 85
- Mar 2014
- 901
February 27th, 2015 05:22 PM #81After ma-overhaul raditor mo, you will notice the difference in your temp gauge. That it will not raise anymore above 1/2 in its indicator marks, it will mostly stay around at 1/3 in its temp gauge.
Sent from my Starmobile UP+ using Tapatalk
- Mar 2014
- 901
February 27th, 2015 06:32 PM #82Have your radiator coolant changed. Flush it out or drain it. It is already a sign of a dirty coolant. If water is in your radiator, then it might be clogged of rust. If a simple remedy like draining, then replenishing it again with water doesn't cure the problem. Then a radiator overhaul/ cleaning is you must do.
February 27th, 2015 06:39 PM #83
High temp at moderate to heavy traffic could also be caused by dying fans. Try to move the blades with your hand (engine off of course). If there is a bit of play or if the rotation is not smooth it might be due for a replacement.
IIRC Prestone sells flushing fluid. You might want to try this for the first drain.
- Sep 2008
- 596
February 27th, 2015 09:37 PM #84Another possible cause could be your water pump (it might need a change already)
- Feb 2015
- 30
March 3rd, 2015 12:25 AM #85Hmmm, ganun ba yun? sige, if I have the budget, will change it soon.
So what coolant na kailangang gamitin? Yung sa thermostat naman, we are going to restore it pero di pa ngayon, wala pa kasing budget saka twing sundays lang ginagamit yung sasakyan pag magsisimba lang. Hehe, pero sinasabi ng mechanic na galing honda mismo na ok lang daw maski wala na daw yung thermostat. Ano ba ang totoo saka ano ang possible na mangyari? Other than that, wala naman problema sa leaks like sa gasket at sa mga hoses. Yung water pump naman ay ok naman. Saka kakapalit ko lang ng timing at balancing belts saka ng tensioners.
This is true bro. Sa lahat nga pala, after overhauling our radiator, nawala na yung overheating ng sasakyan namin. bale ang reading ng temp gauge ko ay stick na sa 1/4 even pag paahon kami ng batasan or sa litex road. Na-resolve na din sa wakas ang problema namin. Yung themostat na lang ang aayusin.
Thanks, I checked them out pero walang Michelin Ang laki ng difference ng price sa Jiga....
Finding the Best Tire for You
