Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 37
    Aug 2006
    Water pump not from Honda should be around 1200-1400 php. Timing belt get it from Honda. it should be around 1500 give or take. As for a shop to replace your belts you might as well go to speedyfix in Shaw or Autotechnika, ask user speedyfix or torque2006 respectively how much they will charge for the parts and service or just the service.
    Aug 2005
    Quote Originally Posted by Puchok View Post
    Sir my Milage is 85,000Kms..tanong ko na rin how much po kaya yung water pump?
    Ganon pala pag lampas na half technically overheating na. tanong ko narin pag ganitong situation na nakikita mo tumataas na ano po precaution? kailngan po ba mag pull over muna pra palamigin engine?
    Update lang po. Kanina check ko ung radiator baka kako hindi naguubos tubig at di nag circulate s reservoir pro ok naman puno ng water ung radiator.
    Ano pa po kaya pwede ko e check on my own bago ko pasilip sa mechanic?
    Salamat po sa lahat ng tulong. God Bless!
    check the water inside the radiator if water is full it means ok.. check the water reservior in every week if nag bawas bah..
    check the radiator cap..
    Mga sir,
    Update lang po.
    Sinilip ko po ung level ng radiator lagi naman pong puno ang ung reservior nagbabawas sya pro konti lang so mukhang normal naman. Then ung Top ng Radiator maninit namn sya pag na sa half ung temp.
    I already replaced my timing belt recently during the 84,000kms reading..also included are fuel filter, oil filter, engine oil, transmission oil, coolant,timing belt, alternator belt..ang di lang nkasama dito is ung Water pump.
    I texted my suking mechanic sabi nya posibble daw na thermostat or Thermoswitch..Possible ba ito ang problem? ano function po nung dalawang ito in relation dun sa problem? magkano po kaya itong Thermostat or Switch?
    Also if kung water pump po problem ano po ung relationship nito dun sa Problem?
    Mga sir pasensya na medyo maraming tanong gusto ko lang din po matutunan kasi yung technical details di lang basta paggawa ng paggawa.
    Thank you po sa tulong & pasensya nyo. God Bless!
    Am no mechanic
    hmmm... since you're only overheating while stuck in traffic, sa tingin ko water pump nga yan, the water pump circulates the coolant sa engine water jacket which cools the engine.
    kasi kung thermostat yan (hindi bumubukas thermostat) kahit tumatakbo ka (not stuck in traffic) aakyat ang temp indicator mo dahil nga stuck-up ang thermostat hindi makapag-circulate ang coolant.
    so I think it's the water pump.
    Sep 2006
    Quote Originally Posted by torque2006 View Post
    all their tips are correct.
    i just want to add another thing: if you're more temp gauge is more than half, technically you're overheating. you don't need it to go up till the red line.
    What?where did you get this info?
    Nov 2003
    it's probably time to replace the thermostat and thermoswitch assuming there are no leaks. a water pump is belt driven so there is no reason for it to stop working if the engine is running.
    Dec 2003
    probably a seized water pump?
    Nov 2003
    on a belt driven pump, if the waterpump seizes, the belt will snap. if the belt snaps, you will know it for sure coz the engine will not run.
    Quote Originally Posted by m_ron View Post
    mga sir is there a real truth reagrding this technical issue?
    Thanks!
    Quote Originally Posted by speedyfix View Post
    Sir speedyfix,
    thank a lot for the reply.
    sir question lang po how much po kaya estimated price ng thermostat and thermoswitch..ano po function nitong thermostat and thermoswitch?
    Thanks a lot.
Overheat Question?
