Quote Originally Posted by userfriendly View Post
Check the following:
1. Coolant level both radiator and coolant tank. btw, how old is your coolant? Its usually replaced every 2 years. Some extended life coolants can go as long as 5 years.
2. Signs of rust sa radiator
3. Is your aux fan working
4. Any leaks
5. You might want to get your mechanic to check your cooling system including your thermostat
Hope this helps.
sir kakalaplit ko lang ng coolant 1 months ago ksabang ng change ng lhat ng fluid..Aux fan ok nalng sya tiningnan ko ok nmn ang ikot nya..sa leak tinitingnan ko nga mabuti pro wala naman ako makitang leak.
