Results 1 to 10 of 37
- May 2006
- 141
November 2nd, 2006 12:14 PM #1Mga Sir,
Tanong ko lang po. MY car is a Honda VTI 2000.
Napansin ko lang pag mainit panahon at nasabay sa traffic bigla tumataas ng husto yung gauge nung temp from half nag reach sya ng bago mag Red Line nakakatakot. Normal po ba ito in any car na pag mainit will behave that way? or my problem car ko? Pag ganitong situation ano dapat gawin, I mean if you are in the middle of the traffic then tumaas gauge temp mo.
Pro pag diretso lang walang trafic constant sa Gitna..pag na trafic lang talaga biglang taas. Lagi ganon kasi pag na traffic lalo pag mainit panahon biglang taas kya nakakatakot baka mag Overheat pag nasa kalagitnaan ka.
TIA & God Bless!
Tsikot Member Rank 4
- Jun 2006
- 2,605
November 2nd, 2006 12:34 PM #2Check the following:
1. Coolant level both radiator and coolant tank. btw, how old is your coolant? Its usually replaced every 2 years. Some extended life coolants can go as long as 5 years.
2. Signs of rust sa radiator
3. Is your aux fan working
4. Any leaks
5. You might want to get your mechanic to check your cooling system including your thermostat
Hope this helps.
November 2nd, 2006 01:12 PM #3
Chances are, your aux fan is defective. Which is why when the vehicle is moving, the temp is normal (the onrush of air cools the radiator), and when the vehicle is stationary, umaakyat yung temp gauge.
Check also your water level or leaks sa radiator or hoses. Pop the hood and gun the engine, and have someone rev it. Observe...problem could be easily solved from there
Toyota is my choice
- Aug 2005
- 2,063
November 2nd, 2006 03:05 PM #4
- May 2006
- 141
November 2nd, 2006 06:14 PM #5
- Jun 2006
- 2,605
November 2nd, 2006 07:28 PM #6Check this thread you have similar problem. http://tsikot.yehey.com/forums/showthread.php?t=32326
Whats your mileage? Is it near 80,000Kms? This is usually the time to change your water pump.
Zombie
- Aug 2006
- 728
November 3rd, 2006 08:34 AM #7all their tips are correct.
i just want to add another thing: if you're more temp gauge is more than half, technically you're overheating. you don't need it to go up till the red line.
- May 2006
- 141
November 3rd, 2006 10:14 AM #9Sir my Milage is 85,000Kms..tanong ko na rin how much po kaya yung water pump?
Ganon pala pag lampas na half technically overheating na. tanong ko narin pag ganitong situation na nakikita mo tumataas na ano po precaution? kailngan po ba mag pull over muna pra palamigin engine?
Update lang po. Kanina check ko ung radiator baka kako hindi naguubos tubig at di nag circulate s reservoir pro ok naman puno ng water ung radiator.
Ano pa po kaya pwede ko e check on my own bago ko pasilip sa mechanic?
Salamat po sa lahat ng tulong. God Bless!
Zombie
- Aug 2006
- 728
November 3rd, 2006 06:51 PM #10precaution? hmmm. number one is bring tons of water and don't get stuck in traffic. or better yet, don't use it until you get it fixed. remember: YOUR ENGINE DETERIORATES EVERY TIME YOU OVERHEAT
(1) gaskets and seals made of rubber loosens/burns/
(2) your engine oil can get into your intake manifold
(3) you lose compression
do all of these:
check your radiator cap (if loose)
check the radiator for water
check the aux fan (if it turns on when your temp gauge is at half)
touch the top your radiator (WARNING: do this at your own risk) if the top is cold even if the temperature in your gauge is at half or more, then you have a seriously clogged cooling system.
check if there's any water leaking from your water pump (tell tale signs are the leak and the rust outside).
85k in the odo right? you're car is due for timing belt and water pump replacement. choose a good shop, these kinds of jobs are delicate.
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
