Check the following:
1. Coolant level both radiator and coolant tank. btw, how old is your coolant? Its usually replaced every 2 years. Some extended life coolants can go as long as 5 years.
2. Signs of rust sa radiator
3. Is your aux fan working
4. Any leaks
5. You might want to get your mechanic to check your cooling system including your thermostat
Hope this helps.
