Results 1 to 10 of 14
- Feb 2008
- 577
February 8th, 2009 02:57 PM #1hi,
i drained my cooling system this morning and i noticed that i have a milky radiator core.
i don't experience overheating or any high temps even though its mid afternoon.
i just want to have it cleared sana... and not to wait for any overheating problems
thanks
Tsikot Member Rank 4
- Jun 2006
- 2,605
February 8th, 2009 03:11 PM #2I think the milky fluid is old coolant. I bet it stinks. You can do a drain and flush. You can use Prestone radiator flush.
Or if you have the budget, do a transtech for a deep clean. It cleans both radiator and engine water jackets. Not sure but I think it cost around 1800 pesos.
February 9th, 2009 03:47 AM #3
Either a head gasket or if its an automatic it could be the cooler for the transmission leaking inside the radiator, If its a reddish color that would indicate the transmission cooler is leaking some on it, just a plain old milky look to it would probably indicate a blown head gasket, blowing oil in to the cooling system,good luck with it.
- Feb 2008
- 577
February 9th, 2009 05:33 AM #4mine is m/t so no tranny oil for sure.
the coolant that i drained didn't look oily... it was just the dry rad core that looks milky.
d*mn if it is blown head gasket... could it really be? are there other tests for this? i don't have white smoke for sure.
February 9th, 2009 06:30 AM #5
looks like you have a oil leaking on your coolant check your engine oil cap if you see milky substance or do a leak down test.
- Feb 2008
- 577
February 9th, 2009 07:58 AM #6
February 9th, 2009 10:19 AM #7
When the coolant last replaced,did you check your coolant again?
However its possible that the car has a problem with the cylinder head gasket usually a sign of a dodgy head gasket, some times the oil from the engine or mixes with the radiator coolant. Other times the coolant mixes with the engine oil producing milky slime in the engine but yours is not.
Remove the oil filler cap to see if there is any white slime on the inside of the cap. If so, unfortunately you will need to have the cylinder head gasket replaced. Im not kidding.
- Feb 2008
- 577
February 9th, 2009 10:29 AM #8yes, coolant is still coolant, not gassy nor oily... also, i'm not loosing coolant nor oil. its really odd
there is no white slime nor milky, nor coffee w/ cream texture. its just plain oil. as for the texture of the oil in the filler cap and dip stick, its just at the right viscosity and color by eye
February 9th, 2009 10:48 AM #9
Hmmmm!
On you engine there is a gasket seals passages between the engine block and the head, where the valves are. There are holes for engine oil and the cooling system.
If the gasket developes a flaw it can allow coolant into the oil passages, or oil into the coolant , and coolant or oil or both into the cylinders( but this is not your case).
Its drivable if its a small crack , but if it gets worse it can cause a lot of damage. I know it cost a lot of money to do this but it would cost you more if you dont keep up. Get a second opinion to a mechanic just dont say anything what I told you, from there, see what he has to say.
- Feb 2008
- 577
Replaced with the Pilot Sport 5 na ata, but the available sizes aren't yet as broad as the PS4.
Finding the Best Tire for You
