Results 11 to 14 of 14
February 9th, 2009 11:51 AM #11
well, you have already flush and drained your radiator. run it again for a few days and drain again to check if you still have the same result. check as well if your radiator has build up some muddy substance inside(you can view it upon opening the cap). if it has, then a radiator overhaul cleaning is already necessary. it's cost less than 1K.
February 10th, 2009 03:21 AM #12
You can check each cylinders for compression test.
Or....
Take off the radiator cap and look for bubbles when you first start the car and the engine is cold. You can also buy a block checker kit from an auto parts store, they are about 20 dollars here, dont know in the Phils if available or how much. They are very simple to use, you put some of the fluid its a little bottle, take off the radiator cap and push is the bottle, start the car and watch to see if the fluid changes color.
- Feb 2008
- 577
February 10th, 2009 08:58 PM #13galing nun a... mukang wala nyan dito.
anyway, just an update, i had someone look at it personally. sabi nya, normal daw yung itsura ng rad core ko... malinis nga daw e, no cleaning nor flushing needed. tanso daw yun... is this true?
i don't bubble when starting with the rad cap off. i don't have a muddy substance inside the rad nor the cap... its just the color of the core.
since i noticed this, i've been draining my rad weekly... the drained fluid does not contain any contaminants of any sort... its all coolant
February 11th, 2009 04:43 AM #14
If it is a rad core this is very harmful to radiator it could cause those small passage to block if gets harden. I would suggest to remove the radiator bring it to any radiator shop to clean it chemically.
Also the heater for your A/C under your dash ... it's all connected to the car radiator ... you must remove those contaminated water on the heather core. what's happened is, if you dont remove them and you used the heather it recirculate back to the radiator and it will contaminate the whole coolant. You need to get your local garage to check it out ... or a specialist Radiator/Heater Repair Agent.
Use 50/50 coolant and diluted water for maximum protection on your engine. Do not used plain water and change the coolant at least once a year. This problem is closed.
