Quote Originally Posted by v6dreamer View Post
When the coolant last replaced,did you check your coolant again?
yes, coolant is still coolant, not gassy nor oily... also, i'm not loosing coolant nor oil. its really odd
Remove the oil filler cap to see if there is any white slime on the inside of the cap. If so, unfortunately you will need to have the cylinder head gasket replaced. Im not kidding.
there is no white slime nor milky, nor coffee w/ cream texture. its just plain oil. as for the texture of the oil in the filler cap and dip stick, its just at the right viscosity and color by eye
