Results 1 to 10 of 54
November 18th, 2013 10:28 AM #1
mga master,
tanong lang kung anong proper na pagbukas ng a/c naka fan ba muna at off ang thermostat o sabay na bukas ang fan at thermostat...? anong mas mabuti para humaba ang buhay ng a/c...?
November 18th, 2013 10:48 AM #2
Doesn't matter really...either way walang problema but I don't see the logic of turning on the fan first bago buksan yun compressor..makes no sense
Sent from my iPad using Tsikot Car Forums
November 18th, 2013 11:06 AM #3
Parang aircon sa bahay? Fan muna bago Low Cool? I don't want to add unnecessary wear and tear to my switches. Basta I make sure that the AC is off before I start the engine to minimize load on the starter and battery. I turn off the aircon first before turning off the engine.
November 18th, 2013 11:46 AM #4
It does make sense imo
The starting current of a motor is really high so thats high current running thru your windings.. Parang hinahawakan mo yung fan blades habang naka on.. Then if you turn your a/c's fan & comp at the same time.. Imagine the power voltage drop in your system if it was in your car.. Which may shorten the life of your alternator/battery or any other electrical component on your system..
November 18th, 2013 11:52 AM #5
Some cars with climate control do not engage the compressor agad when the car is started. Maghihintay sya ng ilang seconds bago kakagat ang compressor. Not sure with manual ACs though.
November 18th, 2013 01:37 PM #6
- Jun 2004
- 1,311
November 18th, 2013 02:15 PM #7I would say it does not matter unless otherwise indicated in your car manual. If unsure best would be to turn on the engine first, then aircon fan, then a/c compressor on a manual a/c system. You can do all that in under 5 seconds anyway.
Tsikot Member Rank 4
- 2,719
November 18th, 2013 02:23 PM #8owner's manual usually suggest the AC should be OFF before starting the car and before turning off the engine ... this ensures lighter electrical load during starting
as to whether the fan or compressor goes first, it doesn't matter ... most owners don't touch the thermostat setting when turning the AC on, so the fan and compressor kicks in simultaneously and does not hurt anything
November 18th, 2013 02:49 PM #9
pag mainit singaw sa loob ng oto (lalo na nabilad ng matagal), todo sa fan muna
habang naka-awang mga bintana.
turning A/C off - thermostat first, then let the fan on for a minute or two.
November 18th, 2013 02:59 PM #10
I keep the A/C switch "on" (and thermostat in my usual setting) and just turn on the A/C a few moments after i start the car (kung malamig naman panahon, i wait for the car to warm a bit and turn on the A/c when my idle is more settled) and turn off before shutting off the engine. Wala naman sira because of that aside from the usual wear and tear.
San mo nabili?
Fire Extinguisher for Car: what brand and type...
