Quote Originally Posted by TheGreenThing View Post
It does make sense imo
The starting current of a motor is really high so thats high current running thru your windings.. Parang hinahawakan mo yung fan blades habang naka on.. Then if you turn your a/c's fan & comp at the same time.. Imagine the power voltage drop in your system if it was in your car.. Which may shorten the life of your alternator/battery or any other electrical component on your system..
the starting current is high but it tapers off quickly also the compressor is mechanically driven by the fan belts.
kung critical ang pag-on and off ng aircon dapat nilagyan na ng special instruction yan sa manual.
