Results 31 to 40 of 63
- May 2013
- 22
August 8th, 2013 10:10 PM #31I tried RainX after using Stainz Out. Since konti pa lang mga rainmarks and unwanted spots sa windshield, nakaya ko naman using rubbing by hand in a circular motion. After, you rinse with water and if properly applied, parang bago and windshield mo, makinis. Then apply RainX, just follow the procedures listed in the bottle.
- Mar 2012
- 95
August 31st, 2013 02:03 PM #32sir Flynn, i bought and tried the ARR which i bought from oxychem corp, sinubukan ko sa estante namin sa tindahan. naalis naman yung gaspang, kaso lang, lumabo yung glass. parang may smoke. ano pang puede ipang alis dito? tnx
- Aug 2008
- 24
September 4th, 2013 01:13 AM #33Fyi, went to oxychem mandaluyong today. They have increased the price to 250php per bottle.
They are also cautious if you know how to use it. They told me to immediately rinse out after applying the ARR. Not to prolong the exposure since lalabo daw. So dapat mabilis lang application.
- Aug 2008
- 24
September 15th, 2013 09:44 PM #34I've tried this on 3 of our cars. Very effective.
Thanks for sharing this method
September 15th, 2013 10:14 PM #35
- Sep 2013
- 8
September 25th, 2013 09:28 AM #36Sir pwede bang gamtin sa side windows ung Elevo Watermark remover?tnx!
- Sep 2013
- 8
September 25th, 2013 09:29 AM #37Pwede bang gamitin ung elevo na watermark remover sa side windows?tnx!
- 508
- Jan 2015
- 17
February 24th, 2015 04:00 AM #39I bought water marks remover at ARR mandaluyong and then followed your procedures on how to remove wter spots on cr glass. And water marks are not removed sir. ;(
- Mar 2014
- 291
February 26th, 2015 11:27 AM #40I tried elevo watermark remover na paste.... it didnt work. Sa sobrang frustration ko ginamitan ko na ng scotch bright non scratch. Ill give it another try this weekend.
high idle RPM at engine start
