Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 63
    Jul 2010
    #21
    Mga gurus ano magandang pang top up after cleaning the glass with elevo watermark remover? Para may protection ang glass
    #22
    Quote Originally Posted by joemelr View Post
    Glass Science Rain Clear or Microtex Stain Guard. RainX afaik, makes the wipers judder. Kung sa sides and rear glass okay lang.
    Jul 2010
    #23
    Sir yun glass science & microtex stain guard madali lang ba i-apply sa wshield,will it not leave uneven marks? I experienced having those uneven marks kc when i used elevo rainfly before visible yun circular strokes lalo na pag umulan.
    Oct 2009
    #24
    thanks bumili na ako ng elevo water mark remover na paste. mas ok daw ito yung liquid ata masyadong matapang.
    pwede din sa side mirrors.
    #25
    Nope. Basta apply and buff off properly.
    Jul 2010
    #26
    whats the proper way of buffing ba? wala kase akong buffing machine, i just do it manually with dry clean cloth in circular stokes till it shines tama po ba?, can you give me some tips sir to be sure lang. thanks
    #27
    No need for a buffing machine. What I meant was to buff/remove the product properly para walang streaking.
    Jul 2010
    #28
    Thanks a lot sir
    Oct 2009
    #29
    mas ok ba gamitin yung elevo water mark remover on a wet windows then apply na yung paste?
    #30
    bumping this thread....
    May 2013
    #31
    I tried RainX after using Stainz Out. Since konti pa lang mga rainmarks and unwanted spots sa windshield, nakaya ko naman using rubbing by hand in a circular motion. After, you rinse with water and if properly applied, parang bago and windshield mo, makinis. Then apply RainX, just follow the procedures listed in the bottle.
    Mar 2012
    #32
    sir Flynn, i bought and tried the ARR which i bought from oxychem corp, sinubukan ko sa estante namin sa tindahan. naalis naman yung gaspang, kaso lang, lumabo yung glass. parang may smoke. ano pang puede ipang alis dito? tnx
    Aug 2008
    #33
    Fyi, went to oxychem mandaluyong today. They have increased the price to 250php per bottle.
    They are also cautious if you know how to use it. They told me to immediately rinse out after applying the ARR. Not to prolong the exposure since lalabo daw. So dapat mabilis lang application.
    Aug 2008
    #34
    I've tried this on 3 of our cars. Very effective.
    Thanks for sharing this method
    Sep 2011
    #35
    Quote Originally Posted by glennjv View Post
    yun ARR ba safe sa clearcoat? Minsan kasi di maiwasan lalo na pag liquid na pumatak sa body ng sasakyan.
    Sep 2013
    #36
    Sir pwede bang gamtin sa side windows ung Elevo Watermark remover?tnx!
    Sep 2013
    #37
    Pwede bang gamitin ung elevo na watermark remover sa side windows?tnx!
    #38
    try using Glaco, a bit pricey but works well for me..
    #39
    I bought water marks remover at ARR mandaluyong and then followed your procedures on how to remove wter spots on cr glass. And water marks are not removed sir. ;(
    #40
    I tried elevo watermark remover na paste.... it didnt work. Sa sobrang frustration ko ginamitan ko na ng scotch bright non scratch. Ill give it another try this weekend.
Acid rain removal and glass protection tutorial
