Page 9 of 22 FirstFirst ... 567891011121319 ... LastLast
Results 161 to 180 of 440
    Apr 2013
    #161
    hello,
    try nyo sa amin Baltaks Merchandise,free check up po,we offer also home service,you can contact us 4013611 or 4970087,look for Leizel or Boss Jun...wala po kayong babayaran hangat di gumana ...tnx..
    Apr 2013
    #162
    hi po
    Try nyo po ipa check sa store nmin,Baltaks Merchandise,free check up po,pwede rin home service,tawag po kayo 4013611 or 4970087,look for Boos Jun or Leizel,....tnx
    Apr 2013
    #163
    hi po,
    Try nyo po sa amin 09299662686,pag wala pa kayo nakuha,Baltaks Merchandise..
    #164
    Quote Originally Posted by myliezel88 View Post
    gud eve,suggest ko sa store nmin Baltaks merchandise,you can contact us 4013611 or 4970087,look for leizel or Boss jun,we offer home service....depende sa napag usapan,tnx
    hello,
    hi po
    hi po,
    Paulit ulit yung post mo.. Hindi na ako pupunta sa inyo kasi siguradong makulit kayo..
    #165
    nyahaha.. paulit ulit post niya. panigurado paulit ulit din balik niyo niyan sa kanila
    Aug 2009
    #166
    sir. saan ba pwde pagawa ng ISUZU TROOPER transmission na reliable at mura? pinalitan ko na ng atf filter at atf pero hard shifting parin kung bago start (tagal kumagat or change shift) thank u
    #167
    Quote Originally Posted by baby_scar View Post
    gas or diesel? (reliability doesn't come cheap. he he)
    Aug 2009
    #168
    Quote Originally Posted by t2erns View Post
    diesel po. bakit tanong u gas or diesel? transmission ung pinagusapan?
    Jun 2012
    #169
    sir ano po kaya sira kapag ayaw magengage ng reverse ng auto trans? lahat gumagana ng maayos yun reverse lang talaga may problema. kotse ko po is 99 model honda civic vti. san ko po kaya pwede ipadiagnose yun kotse? sampaloc area lang ako
    May 2013
    #170
    same problem ng automatic transmission
    1.matagal "minsan" mag shift from 1st gear - 2nd gear or minsan 2nd - third
    >ginagawa ko nilalaro ko nalang ung gas pump hanggang sa kumagat na 2nd or 3rd ung gears minsan ayaw padin (5-10min 1st gear in highway)
    >pano ba makikita un ATF ng nissan serena d kc namin alam kung anong level na?
    2.may kinalaman ba un transmission sa madalas na pag overheat ng sasakyan?
    Nissan serena 1992 or 1994
    diesel 2.0
    Cavite
    Aug 2012
    #171
    Sabi sakin ng SA ko sa toyota nag wwarm up daw yung ATF kaya kapag bagong start matagal mag shift from 1st to 2nd. Medyo hirap sa umpisa ng andar then after a while normal na.
    #172
    transmission for the trooper gas engine is different from those with diesel engines
    Apr 2005
    #173
    I've been browsing this thread for possible places to take my vitara if the AT should start to fail or show signs of it.
    I was wondering if anybody here has had their AT repaired or overhauled by "Fronte" in Banawe? I've browsed some Suzuki forums and they have recommended this shop as the shop to go to for AT repairs. Anybody with experience having their AT serviced by them?
    Aug 2009
    #174
    reliable automatic transmission shop?
    #175
    Need help finding a reliable AT specialist in manila for my Nissan Exalta 2001. Hirap mag shift to higher gears, you have to pump the gas pedal to shift up. Please share your experience with your mechanic, thank you po.
    Apr 2008
    #176
    usually its the seals, pag matagal mag engage...hindi maka build up ng pressure para mag compress yung clutches ^_^
    #177
    Mga peeps patulong naman kung saan pwede makabili ng shift solenoid ng Honda crv second gen. or pwede ba marepair. salamat
    yun kasi ni rereport ng computer scanner ng Honda . kasi pina repaste ko cylinder head sa isang shop and pinalilitan ng pulley pag balik ng mekaniko umilaw and nag blink yung d sign. tapos di na sya nag shift ng gear stuck sa 2nd gear. di ko alam kung tama pagkabalik ng mekaniko kasi binaba yung makina dahil kailangan daw para madukot yung pulley.
    other than that wala naman sira yung crv kundi sa tumataas lang temp.
    #178
    Car is Honda Civic 1.6 a/t 2003 (Dimension Body)
    Excessive shiftshock from N to D then all forward gears, pati kapag nagdownshift. (kapag reverse wala naman)
    Remedies done:
    ATF replaced to no avail.
    Scanned already by Honda to check solenoids/code errors wala naman lumabas.
    Was informed something about pressure kaya malakas ang shiftshock.
    Ano ba mas ok, surplus tranny or rebuild? ...iba iba kasi mga opinions... yung iba rebuild para sigurado yung laman sa loob eh bago.. yung iba naman surplus tranny... thanks for your inputs.
    #179
    Quote Originally Posted by junerski View Post
    Remedies done:
    mas maganda ang rebuild (if done properly) kaysa sa surplus which hinde ka sure kung gaano pa itatagal
    Apr 2008
    #180
    i think problem is sa gate valves ng valve body mo, nag stick sya, hindi gumagalaw ng maayos, thats whats causing the jerks ^_^, have it cleaned.
Automatic Transmission Specialist
