2nd hand ko syang nabili and 2 yrs na syang nasa akin, wala naman syang problem, masarap idrive, mabilis ang reaction ng makina, aside lang sa konting basa ng oil yung pang ilalim nya when i acquired it. overall, satisfied ako sa performance nya as a galant until lately pansin ko may parang grinding / humming sound pag 2nd gear and up.
so i brought it to a trusted mechanic and my car was serviced for change gear oil, bothering kasi halos 0.5 liter lang yung nakuhang langis and parang chocolate na yung consistency nya. i drove it home and everything seemed okay.
the next day, tagas yung gear oil sa garahe, ibiniyahe ko pabalik sa mechanic but that time I felt something new, parang 'sliding clutch' ko, nagshoot ung rev pataas pero naiiwan speed nung sasakyan...
i told the mechanic about the leak and the 'sliding clutch' feel. after ng mga disccussion.. i agreed na ibaba yung transmission para makita din yung clutch parts.
eto ang mga pinalitan/ginawa after, output shaft/axle seals, rear main seal, refaced flywheel, replaced clutch lining, replaced pressure plate and changed gear oil (ulet)... i was there 9am and natapos sila ng mga ~4pm... it was okay when we test drive pero may grinding sound parin... sabi ng mechanic, try lang daw gamitin muna kasi baka di pa daw napasok ng bagong oil yung mga parts, eventually and hopefully it will be gone daw if not, bubuksan yung transmission para makita yung bearing ng gears baka daw yung ang maingay...
almost 3 weeks ko na syang ginagamit pero di parin nawawala yung parang grinding / humming noise kapag sa 2nd gear pataas...
and still there is this 'sliding clutch' na feel...
eto pa, one time napa engine break ako sa first gear, nag di-disengage yung kambyo, sinubukan ko mag engine break sa ibang gears pero sa 1st gear lang sya bumibitaw.
Question:
1. Napalitan na yung clutch lining and pressure plate and refaced na flywheel, bago gear oil, posible ba na yung transmission ang mag cause ng 'sliding'?
2. Should i go for rebuilding the transmission?
