hello,
try nyo sa amin Baltaks Merchandise,free check up po,we offer also home service,you can contact us 4013611 or 4970087,look for Leizel or Boss Jun...wala po kayong babayaran hangat di gumana ...tnx..
hello,
hi po
Try nyo po ipa check sa store nmin,Baltaks Merchandise,free check up po,pwede rin home service,tawag po kayo 4013611 or 4970087,look for Boos Jun or Leizel,....tnx
hi po,
Try nyo po sa amin 09299662686,pag wala pa kayo nakuha,Baltaks Merchandise..
nyahaha.. paulit ulit post niya. panigurado paulit ulit din balik niyo niyan sa kanila
sir. saan ba pwde pagawa ng ISUZU TROOPER transmission na reliable at mura? pinalitan ko na ng atf filter at atf pero hard shifting parin kung bago start (tagal kumagat or change shift) thank u
sir ano po kaya sira kapag ayaw magengage ng reverse ng auto trans? lahat gumagana ng maayos yun reverse lang talaga may problema. kotse ko po is 99 model honda civic vti. san ko po kaya pwede ipadiagnose yun kotse? sampaloc area lang ako
same problem ng automatic transmission
1.matagal "minsan" mag shift from 1st gear - 2nd gear or minsan 2nd - third
>ginagawa ko nilalaro ko nalang ung gas pump hanggang sa kumagat na 2nd or 3rd ung gears minsan ayaw padin (5-10min 1st gear in highway)
>pano ba makikita un ATF ng nissan serena d kc namin alam kung anong level na?
2.may kinalaman ba un transmission sa madalas na pag overheat ng sasakyan?
Nissan serena 1992 or 1994
diesel 2.0
Cavite
Sabi sakin ng SA ko sa toyota nag wwarm up daw yung ATF kaya kapag bagong start matagal mag shift from 1st to 2nd. Medyo hirap sa umpisa ng andar then after a while normal na.
I've been browsing this thread for possible places to take my vitara if the AT should start to fail or show signs of it.
I was wondering if anybody here has had their AT repaired or overhauled by "Fronte" in Banawe? I've browsed some Suzuki forums and they have recommended this shop as the shop to go to for AT repairs. Anybody with experience having their AT serviced by them?
Need help finding a reliable AT specialist in manila for my Nissan Exalta 2001. Hirap mag shift to higher gears, you have to pump the gas pedal to shift up. Please share your experience with your mechanic, thank you po.
usually its the seals, pag matagal mag engage...hindi maka build up ng pressure para mag compress yung clutches ^_^
Mga peeps patulong naman kung saan pwede makabili ng shift solenoid ng Honda crv second gen. or pwede ba marepair. salamat
yun kasi ni rereport ng computer scanner ng Honda . kasi pina repaste ko cylinder head sa isang shop and pinalilitan ng pulley pag balik ng mekaniko umilaw and nag blink yung d sign. tapos di na sya nag shift ng gear stuck sa 2nd gear. di ko alam kung tama pagkabalik ng mekaniko kasi binaba yung makina dahil kailangan daw para madukot yung pulley.
other than that wala naman sira yung crv kundi sa tumataas lang temp.
Car is Honda Civic 1.6 a/t 2003 (Dimension Body)
Excessive shiftshock from N to D then all forward gears, pati kapag nagdownshift. (kapag reverse wala naman)
Remedies done:
ATF replaced to no avail.
Scanned already by Honda to check solenoids/code errors wala naman lumabas.
Was informed something about pressure kaya malakas ang shiftshock.
Ano ba mas ok, surplus tranny or rebuild? ...iba iba kasi mga opinions... yung iba rebuild para sigurado yung laman sa loob eh bago.. yung iba naman surplus tranny... thanks for your inputs.
i think problem is sa gate valves ng valve body mo, nag stick sya, hindi gumagalaw ng maayos, thats whats causing the jerks ^_^, have it cleaned.
