Newbie here, need advice po. bought a 1997 honda civic barely 2 month ago. Ok naman andar until di na nagana yun speedometer nya. I went to banawe to buy a replacement speed sensor for a 97 civic only to find out na un transmission di compatible sa speedsensor na nabili ko. So ginawa ko took the existing speedsensor to banawe and found out na pan ESI na speedsensor un nakakabit. So ibig sabihin napalitan na ang automatic transmission ng kotse. My dilema is i took it to rapide to have an ATF flush done at nakita na may leak ang mga seals sa ilalim. At present kasi kapag nakahinto ang kotse nakakaramdam din ako ng vibration sa kotse and minsan parang di agad respond ang gas pag tinatapakan.. which brings me to why i wrote here po... iniisip ko kasi na papalitan na ang transmission at ibalik sa 97 na civic uli.. tama po ba na gawin ko un o stick na ako sa existing na transmission at hayaan na palitan ang seals. Problem ko kasi if binuksan ang transmission at may iba pa makita na problema since it is a 20 yr okd transmission na din. Would it cost more to replace it o paayos na lang ng existing na transmission?
Sir anong model ng car mo?
Sent from my ASUS_T00I using Tsikot Forums mobile app
when was the last time you had your cvt fluid changed?
I wonder if they used the right cvt fluid. im not sure if the current cvt fluid for the mirage/g4 is backwards compatible with the old 1st gen cvts...
thanks for the reply. how will i know po kung tamang cvt fluid ang inilagay nila. Normally when you send your car for servicing in casa, you just put your car in the workshop and you just wait at the lounge. Is there a way to check po ba? and in case maling cvt fluid ang inilagay nila, may liability po kaya ang kasa?
ano naka lagay sa invoice or receipt?
old tranny bro. almost 20yo. it could be solenoid or actuators or tcm or maybe just the fluid..
or baka need cleaning ng sensors...
2005 pala akala ko older.
just curious, every 2-3yrs ka nag palit ng cvt fluid?
ala ako alam for your vehicle. try fb search bro.
5yrs is toooo long. even if the tranny is sealed, the cvt oil degrades over time.
most unopened oils have a shelf life of 5years. paano pa pag nasa transmission na..
