Page 6 of 22 FirstFirst ... 234567891016 ... LastLast
Results 101 to 120 of 440
    Oct 2011
    #101
    UPDATE LANG PO NATEN ITONG THREAD. I have 1998 Honda Accord VTiL. As a backgrounder my car's AT was rebuilt about 6 years ago but lasted only 3 months (waste of money). I then had a surplus AT put in at Banawe. The shifting was not as it was used to with ocassional delays and "kaldags". But this was all they could do for my car so I paid them and was on my way. This tranny lasted for 6 years with the AT deteriorating early this year. It became unbearable that I decided to finally do something about it. I was contemplating on 3 options:
    Option 1 - CASA Rebuilding - Here I will spend about P60K but this should be the sure way to go since this is "CASA" Unfortunately considering the year and value of the car it seemed unreasonable.Plus the fact that they will surely ask you to replace other parts to ensure quality and so that they can apply the warranty.
    Option 2 - LUCAS Transmission - They offered P14k labor to rebuild plus parts which should cost around P12k. That's P26K of uncertainty.
    Option 3 - AM Bulaong - He offered P15K replacement with 6 months warranty old tranny as trade-in. That's P15K on uncertainty.
    So I went for the cheapest option but with the high recommendations in this forum as a backup.
    DAY 1- I brought the car to Mr Alex last thursday morning (11am since my car was number coding) and his crew began dismantling the tranny. A new tranny was installed at about 5pm. Result - Same banana, Slipping and kaldags all the way. frustrated I Left the car for them to work on it again.
    DAY 2 - Went back the nest morning and they have just finished installing a new tranny. Waited until after lunch and went for a test drive. Result - Same banana, slipping and kaldags all the way. So they dismantled the tranny again for the 3rd time, got a new tranny and they started installing the new one. Finished by 6 pm and went for a test drive. Result - The car was not slipping but when you put it to D it wasn't moving at all! Frustrated but with beliefe that the 3rd day is a charm I went home with my son.
    DAY 3 - Was up late that night so I woke up at around 9am. Called Alex at abround 11am ans asked him if the car has been fixed yet. He said "Ok na sya maganda na takbo." I said to my self Wow! this I have to see. Went there at around 3pm got in the car for a test drive. Result - Wow! The car was running smooth and fast. I wasn't really expecting the car to run the way it was running now (since my last replacement). I had to give a big tip for the boys who dismantled the tranny 4 times.
    I hope this tranny will last for the remaining life of the car. I was amazed on how Alex took the problem as a challenge for him, Only downside to the whole experience was the waiting and the dirty feet you get for the waiting when you wear slippers. I also anticipated that the boys might not be able to tighten all the bolts and screws properly so I brought the car to the nearest shop with lifters. My anticipation was right and I have 3 screws loose (stabilizer link, and I forgot the other 2) But all in all I highly recommend them!
    Will be back for the ATF change.
    Mr. Alex forgot my receipt for the 6 months warranty. Will just drop by one of these days. Thanks!
    #102
    Quote Originally Posted by zephyr08 View Post
    Sirs/Ma'am need your help:
    Car: Civic 2001 (VTEC3 aka Dimension)
    Problem: Slight delay changing from P to D or from N to D from stand still. When you step on the gas as soon as you change to D, the car will jerk and will hear a "tug" sound. Usually will wait for half a second and wait for it to engage into drive and then step on the gas.
    Car shifts from all 4 gears without slipping or delay, and will shift on the right RPM depending on how much pressure you put on the gas pedal.
    Car still has a lot of torque, just went to Tagaytay just this long weekend with the car fully loaded (5 adults with cargo) and still very satisfied with the pull of the vehicle.
    Can anybody confirm that the problem might be a solenoid or a relay? I'm planning to have my ATF changed by a dialysis machine one of these days. But I'm not quite sure if the ATF they will use (Mobil1 or any other dexron III atf instead of Honda's expensive ATF-Z1) will help or just aggravate the problem.
    I can live with the problem. I'll just make sure that I shift in D before the traffic lights go green, but I want to make sure that I'm not aggravating the A/T problem and will in turn be a costly repair in the near future.
    Any inputs/suggestion is welcome. Thanks in advance.
    Hi All,
    Just an update, I went through the ATF change using the dialysis machine during this long weekend (Finally!). It was done in Exalta in N. Roxas near the corner of Banawe. All I can say that it was worth it. The shift shock (slight delay changing from P to D or from N to D from stand still that causes the jerk when going into motion) was gone except when you do it on purpose (when on N, press on the gas then change to D, a big no - no), but in normal driving conditions the shift delay and shock was gone and the car feels it has more torque.
    The owner of Exalta was adamant to buy the ATF-Z1 in casa, I bought 8 bottles (and now 4.4k poorer), but only 6 were used. The best part is you can see the condition of the old and new fluid when its being drained/replaced and by the time you see the condition of the old fluid, you'll ask yourself that why didn't you do this sooner. The "dialysis" machines were relatively new (not older than 2 yrs tops) and for 600 php the service was worth it.
    The only bummer was the expensive ATF-Z1, that costs 550 a bottle. Well no one lives in perfect world and who am I to complain? I just have wish that ATF-Z1 was cheaper
    Just my .02 cents. Peace.
    Sep 2011
    #103
    Mga sir's napa dialisys ako kanina sa fronte cost me 3.2k kc sobrang dumi ng atf ko but yung problem na jerk from P/N to D Di parin nawala. Ano kya prob ng transmission ko? Electrical lang kaya? Solenoid? Relay? Tulong nman po.
    Car ko galant 88
    #104
    Quote Originally Posted by jaimeframos80 View Post
    Car ko galant 88
    Sir maraming possible causes eh:
    1. Pwede rin solenoid. Pag mabagal mag switch on ung solenoid at mag papasok ng ATF sa needed chambers, pwede mag cause ng Shift Shock.
    2. Pwede din barado na yung filter ng AT nyo, di ko lang sure kung may filter yung Kotse nyo.
    3. Pwede din di na kumakapit ung clutches sa 1st gear. Eto pinaka masama. Kasi kailangan na ng rebuild neto.
    Mas maganda patingin nyo na po sa AT specialist, para sure.
    Apr 2008
    #105
    [QUOTE=bong06;1810361]Good Eve, check out this website and give these guys a call, maybe they can help you out, had the same problem and went to honda cavite, one of the service advisors referred me to these people, hope you get your car fixed, God Bless
    http://www.**************/index.php/...ALIST+/+REPAIR
    Jun 2011
    #106
    paki singit lang ako manga sir,paki tawagan nyo 09212474805 09281904001 ok silang gumawa ng tranny pakisabi nalang c mike ang nag bigay ng # tnx
    Sep 2011
    #107
    * zephyr08. Thanks Sir
    *mike, anong name? and saan yung shop?
    #108
    Hi All,
    That's fine. I used up 25 bottles of ATF to clear up the A/T of a Corona Exsior i bought before; the previous, first owner never bothered to change her ATF in the 55,000kms and 10 years she had the car (buti nalang low mileage siya).
    Jun 2004
    #109
    Any other Automatic Transmission Specialist that you can recommend aside from AM Bulaong? Preferably QC area.
    I have Nissan Altima, you need to drive the car to about 60KPH in D2 before it can engage to D4/D.
    Thanks.
    Mar 2007
    #110
    paki tawagan ito, 8068845, look for norman gomez.pki sbi ni refer ka ni george roxas...dyan ako nagpa rebuild ng tranny...1 year warranty pa...nun october ginawa yung sa crv ko so far wala namang problema at gumanda pa ang hatak...
    Oct 2009
    #111
    Any recommend shop na nag dialysis style near Pasig? I heard they will top up an oil then start the car for a minute then drain then top up again until the oil is clean. Thanks!
    Nov 2011
    #112
    Guys mention ko lang bad experience ko para di na maulit sa iba. I had my accord auto tranny fixed by bong06 but they were never able to fix it. Marunong sila magbaklas at magkabit but I don't think that they are specialist. Binigay nila sa akin ang kotse may jerk sa downshift and now wala pang 2 months nagjejerk na at cold start as if it was never overhauled. I spent 32k and it was not worth it. Ok sana kasi may 1 year warranty but para saan ang warranty kung hindi na nila alam ayusinb ang tranny mo? Iintay ka lang ng maghihintay. Ang masama pa nito bong06 is now unreachable. Just beware guys para di na kayo maloko.
    Jun 2007
    #113
    Quote Originally Posted by milesbocci View Post
    Naku, kung totoo nga ito back job yan sir. try mo ibalik sa kanila baka ma resolve pa yung issue at para sa warranty din, parang nakapag pa qoute na rin ako dito sa bong06 buti na lang di na ko nag pa overhaul, 5 speed conversion yung pinagawa ko ibang mekaniko
    Nov 2011
    #114
    I tried calling and sending a message pero di nagrereply at di sumasagot e. But the bottomline is not recommended sila talaga. On top of this, yung bong06 sya din pala yun. Pinopromote nya yung sarili nila. Di totoo na nagpagawa sya. Tanggap ko na loss ito. Sana lang wala na maloko.
    #115
    My '94 Land Cruiser 80 A/T wasn't shifting to overdrive. It would only shift until 3rd gear and was really killing my fuel economy on the highway.
    Fearing an expensive repair (a surplus A422F transmission costs around Php150k) I took it to Dr. G's Car Clinic in Selecta Drive Quezon City (accessed via A. Bonifacio avenue). Their guy Nestor checked all the connections to the computer box, the O/D solenoid and other associated parts. In the end it was just a wiring problem (thanks to the previous owner) and was easily corrected. I really admire how much time and effort they put into checking each and every wire from the tranny to the ECU instead of just suggesting replacing the tranny as most other shops would do.
    The shop is primarily a Land Cruiser specialist shop but they work on all brands also.
    Dec 2007
    #116
    our mechanic have fixed our CRV AT and he works home service kaya makita mo talaga how he does it.. pm na lang for me if need he's contact information...
    Feb 2010
    #117
    Quote Originally Posted by philander View Post
    Thanks.
    Paps you may try Max Reyes (09172089786) or Boy (09105815076), in Banawe, marami na silang napatinong A/T from. Normally if hindi na makuha sa rebuild, they replace the whole A/T tranny using Japan Surplus tranies. Give them a call..
    Feb 2006
    #118
    Guys please read this para sa mga avid costumer ni BULAONG sa banawe,ninakawan ako ng speed sensor ng pajero (7k value) ng mga bata ni bulaong nung nagpagawa ako sa kanila, dinala ko ung pajero sa kanila buhay na buhay ang speedometer,pagbalik ko sira na! malas ko naman..wala po akong nagawa kundi bumili ng replacement. kaya konting ingat lang po sa mga nagpapagawa ke BULAONG. swertehan lang pala magpagawa sa kanila,nadala ako sa dami ng positive feedback dito sa tsikot.
    May 2010
    #119
    Good Day mga Sirs!
    pag slipping ba overhaul na talaga ang tranny? kasi napapansin ko sa auto ko, lagi akong babad sa 2k rpm. kapag paakyat kelangan 2.5k rpm. pero pag hinataw naman. ok naman yung response. yung 2 and L at overdrive gumagana lahat. and napansin ko hindi siya umaabante kapag nakalagay sa D tapos release ang brakes. meron naman pero onti lang. sa R naman halos walang movement. Slipping na ba to mga Sir? many thanks!
    Car: 97 space wagon.
    Apr 2008
    #120
    same question here. ano kya possible solution for slipping sa tranny???
    mine pag umakyat na ng 3k rpm bigla na mag slip, (you may feel na para kng bigla naka nuetral at ayaw na magkumagat yun gear) so binibitawan ko nlng yun gas then when the rpm drops tapak ulit.
