Results 31 to 40 of 439
September 20th, 2010 04:02 PM #31
September 20th, 2010 06:02 PM #32
- Aug 2010
- 32
September 21st, 2010 11:15 PM #33Siya lang kase nakaayos ng A/T ng Pajero ko kaya sinabi ko sa kanya na tutulungan ko siyang dumami ang customer. Saka pinaka mura na ang labor nila ng tatay niya. Pag nalaman pa nilang malaki na nagastos ng customer bago ipagawa sa kanila kulang nalang ilibre yung ginawa nila.
Para sigurado kayo canvass muna then saka kayo pumunta kay Leonard. Saka sasabihin nila kung surplus yung gagamitin at ano ang pros and cons kung bakit "surplus" ang gagamitin nila.
- Apr 2008
- 112
September 23rd, 2010 11:36 AM #34check nyo iyung 006 Auto repair shop kung willing kayo mag travel ng konti, malapit sya sa honda cavite, taga honda quezon ave. iyung chief mechanic dun, galing sa automatic lalo na kung honda, mababa pa ang price, sa sulit.com.ph ko sya nakita, ito iyung link niya http://www.sulit.com.ph/index.php/vi...r+/+Specialist ,1 year warranty, parts and labor, talo pa ang casa... hehehehehe
- Aug 2010
- 7
October 6th, 2010 11:10 PM #35I have no problem sa expertise nila BULAONG. Improve lang nila workmanship. I bought surplus tranny from BULAONG last month. Iyong pinalitan kasi ang tranny ng Altis ko, hindi mahigpit pagkakabit sa pan oil seal so nag leak tapos binalik ko the next day para ayusin nila.
After one month, I decided to flush the ATF iyan kasi advise nila BULAONG . Since busy ako , I just went to Speedyfix sa SHAW blvd malapit kasi kami doon at doon ko nalaman may leak galing OIL SEAL ng transmission at sa CV joint (hindi mahigpit at magandang tie wrap ginamit kaya nag leak grasa). Inayos naman nila lahat ng nakita nila.
I used Royal Purple ATF (fully synthetic ATF). Ok itong brand na ATF, mahal lang nga pero ang laki improvement sa shifting.
- Aug 2010
- 32
October 9th, 2010 09:48 PM #36I don't think you can give the credit of your improve shifting to "royal purple" . It's a must to have your ATF replaced after a week of installing a new transmission. Pag bago ang transmission na kinabit normally may mga shavings ng metal na nag circulate sa system ng transmission hence causes abnormal shifting. That's why they highly recommend that you have your ATF replaced after a week . Yung type of ATF na gagamiting naten is for the prevention of wear and tear. This is just my own opinion. When I had my ATF replaced nilagyan ni BULAONG ng magnet sa oil pan para daw dun pumunta ang metal shavings/dirt incase meron sa system. When he replaced it wala daw kaseng nakalagay na magnet sa pan kaya daw hindi maganda shifting ng sasakyan ko. Open si Bulaong sa mga backjobs. Don't hesitate to bring it back to Leonard pag may problema pa sasakyan mo.
Wrathbu
- Aug 2010
- 7
October 12th, 2010 02:37 PM #37hi Wrathbu. I appreciate your comments. Still observing the shifting. I still experience jerk when accelerating coming from semi full stop. Its like shifting from 1st gear to 3rd gear bypassing 2nd gear. When I use D2, I did not experience jerking when accelerating. This problem has not be solved though Leonard did some adjustment already.
Thus, I don't know where the problem is. Definitely this surplus transmission behaves much better than the one I used before. Will try to call Leonard. I don't if the ECU/TCU has something to do with this. It may reprogramming? I really don't know.
- Apr 2008
- 112
October 13th, 2010 09:59 AM #38boss save the headache, dun mo na patingin sa mechanic ko iyan, HONDA AUTOMATIC TRANSMISSION SPECIALIST FROM QUEZON AVE, MAY SHOP NA SYA SARILI SA CAVITE, SI MEL CASABA... E2 LINK
save the headache pre, i did
- Aug 2010
- 7
October 13th, 2010 03:13 PM #39Under warranty pa naman iyong surplus tranny. I also called up Mel (Honda Tranny specialist), sabi niya ipa test ulit kay Leonard tapos kung meron pa din jerk, ipapalit ng new surplus transmission ulit since under warranty pa naman.
Also talked to Leonard, he will check daw and replace the tranny if needed. I hope makakuha naman ako ng matinong surplus tranny.
- Aug 2010
- 32
October 14th, 2010 02:57 AM #40Hi jkwokng! As you have stated in your previews post that your car was submerged in flood. It's a possibility that there's other problem with your car that may contribute with the jerking when accelerating. And, I know how it feels to bring our car back and forth despite our busy schedules. I just hope that all the problem with your car will be resolved the soonest.
Traffic!
