Results 1 to 20 of 89
Threaded View
  1. #10
    pang b16 hanapin mo..better kung may nakita kang galing sa b16a, basta ata b-series ng engine ng honda ok na un..
    ang prob kung palit ka ng a/t is ung connectors, sa much as possible dont splice, dapat direcho lang ang wiring, kasi sa labas yan and prone sa flood water kung sakali...kung no choice but to splice the wire, be sure to use ung heat-shrinking rubber insulator (aside sa electrical tape ha) sa connection point to prevent short circuit if ever rains come up thus producing flood...
    kaya for maximum cost, manual talaga kung gusto maximum performance..
    ask mo si sir speedy kung mayroong bang low-pressure turbo for your matic civic... or ganito, paconvert mo sa manual yan, pero you'll need a:
    clutch pedal/master assy., flywheel, pressureplate, release bearing, clutch plate... basta kunin mong m/t may LSD na para masaya...
Automatic Transmission Problems [Merged]
