Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 58
    Aug 2012
    #31
    Quote Originally Posted by r_delro View Post
    So kung metal screen lang siya. Linisin lang siya or palit din dapat. Is this a necessary replacement item?
    Linis lang. Pag damaged, doon lang need palitan.
    Jan 2009
    #32
    Quote Originally Posted by newtocar View Post
    Sir, aside from what is stated in the manual, is there any other way to check the condition of ATF for D4D engine. May dipstick din ba sya like sa engine oil?
    Yup.
    Dec 2009
    #33
    matagal dumumi yung metal screen na yan kung regular ka nag atf change... meaning every 40,000kms max....
    if matagal ka magpalit atf, beyond 40,000kms, pag tinangal mo yung screen na filter na yun madaming dumi sobra.
    what you need to clean is the magnet sa loob ng atf pan, madami metal fillings na nag clump together around the magnet.
    i will advise you to use the original atf pan filter should you choose to replace it.
    a branded ATF with spec higher than what you need is also advisable, that way you are also buying a little further of margin.
    Quote Originally Posted by miko101130 View Post
    use what is spec'd and compatible.
    some are higher spec'd but are backward compatible and some aren't.
    Apr 2015
    #35
    Yup.
    Ah okay, sir pwede ba padanin jan sa lagayan ng dipstick ang pag lagay ng ATF, gamitan ng funnel?
    Aug 2012
    #36
    I just checked Mitsubishi ASX maintenance schedule. Under normal driving condition, no mention to change ATF, even up to 240,000 km. But under severe driving conditions, it says change ATF every 48,000 km or 24 months. No mention to change ATF filter, unlike for engine oil.
    #37
    That is correct bro.
    But I am not taking any chances and so I am having my atf replaced in a few weeks....
    And I guess the casa interprets this as replace....
    P1000 for the service bro. Asked them an hour ago... They were recommending the use of a cheaper dexron3 atf to flush out. Cost is P280 per liter. I think I will be using the original Toyota atf for everything. BTW, asked Bicutan for a quote, they were recommending 3 liters of atf only si just drain and replace.... But total cost of pms at 40kkm is P15k.....
    more or less pareho lang din pala sa customer's cradle ang cost ng pag-gamit ng transtech machine nila
    i was told na pwede din iyong castrol equivalent ng oem atf ng mitsu kaso to play safe i stuck it out w/ the oem atf na lang din. iyon nga lang, it did cost me a pretty penny ika nga
    Jun 2009
    #38
    Accdg to this, i should change my atf in my ranger every 250,000kms. My SA says every 80,000 kms though. Kanino ba ko maniniwala? Lol imageuploadedbytsikot-forums1443328729.460347.jpg
    #39
    Quote Originally Posted by dcph172 View Post
    Mas maniwala ka sa documents or manuals kaysa sa mga SA.
    Aug 2012
    #40
    Wag maniwala sa SA. Best to inspect the ATF first. For Ford Ranger, change ATF at:
    Normal driving conditions: 240,000 km
    Extensive idling and driving at low speeds: 170,000 km
    Towing: 100,000 km
    Operating on dusty conditions: 48,000 km
    Off road conditions: 48,000 km
ATF change
