Quote Originally Posted by r_delro View Post
So kung metal screen lang siya. Linisin lang siya or palit din dapat. Is this a necessary replacement item?
matagal dumumi yung metal screen na yan kung regular ka nag atf change... meaning every 40,000kms max....
if matagal ka magpalit atf, beyond 40,000kms, pag tinangal mo yung screen na filter na yun madaming dumi sobra.
what you need to clean is the magnet sa loob ng atf pan, madami metal fillings na nag clump together around the magnet.
i will advise you to use the original atf pan filter should you choose to replace it.
a branded ATF with spec higher than what you need is also advisable, that way you are also buying a little further of margin.
