Page 2 of 2 FirstFirst 12
Results 21 to 40 of 58
    That is correct bro.
    But I am not taking any chances and so I am having my atf replaced in a few weeks....
    And I guess the casa interprets this as replace....
    P1000 for the service bro. Asked them an hour ago... They were recommending the use of a cheaper dexron3 atf to flush out. Cost is P280 per liter. I think I will be using the original Toyota atf for everything. BTW, asked Bicutan for a quote, they were recommending 3 liters of atf only si just drain and replace.... But total cost of pms at 40kkm is P15k.....
    more or less pareho lang din pala sa customer's cradle ang cost ng pag-gamit ng transtech machine nila
    i was told na pwede din iyong castrol equivalent ng oem atf ng mitsu kaso to play safe i stuck it out w/ the oem atf na lang din. iyon nga lang, it did cost me a pretty penny ika nga
    Jun 2009
    Accdg to this, i should change my atf in my ranger every 250,000kms. My SA says every 80,000 kms though. Kanino ba ko maniniwala? Lol imageuploadedbytsikot-forums1443328729.460347.jpg
    Quote Originally Posted by dcph172 View Post
    Mas maniwala ka sa documents or manuals kaysa sa mga SA.
    Kada 30k kms ako magpalit ng ATF. Pero minsan ay binabase ko din sa amoy at kulay. Pag medyo parang sunog or light brown na ang kulay, palit agad kahit wala pang 30k kms.
    The best pa rin kung via DIALYSIS ang pagpalit pero medyo masakit sa bulsa. Kaya traditional change oil technique ang ginagawa namin. We measure the amount of fluid drained para may idea kung gano karami ang ipapalit. This is better than not changing the fluid at all.
    I own a Mitsubishi Space Wagon. Dexron III (Mobil) ang dating nilalagay pero hindi maganda ang shifting. Moreover, nung mag change oil kami ay maraming metal shavings, ebidensya ng poor performance nung lubricant. Then a friend of mine suggested the use of SPIII. Yup, it worked like a charm. From then on, I use Syngard CVT (compatible with SpIII) Php450 per liter.
    Dexron III is compatible with larger A/T like Pajero, Montero, etc... For smaller vehicles, like mine and Lancers, better use a finer ATF = SPIII. Php800/liter ang SpIII sa Mitsubishi casa.
    Apr 2012
    Quote Originally Posted by jjmd3_787 View Post
    If I'm not mistaken SP rating ang Mitsu na ATs like Hyundais. I suggest hanap ka ng ZIC na SPIII. Mura lang yan per litre nasa 400 yata or 450 search mo sa olx si mr liempo yung nagbebenta din ng zic oils. Sa kanya ako kumuha ng SP IV na pra sa Grand Starex ko
    Mar 2005
    Castrol transmax SPIII gamit ko sa Montero and 09 Santa Fe. 320 lang per lit sa Ace Hardware.
    How much yung SpIV niya? Pagka SPIV ang gamit di ba 80k ang palit?
    Aug 2012
    Wag maniwala sa SA. Best to inspect the ATF first. For Ford Ranger, change ATF at:
    Normal driving conditions: 240,000 km
    Extensive idling and driving at low speeds: 170,000 km
    Towing: 100,000 km
    Operating on dusty conditions: 48,000 km
    Off road conditions: 48,000 km
    Jan 2009
    If you predominantly drive in Metro Manila, the SA's advice of 80k km seems sound. If you compare driving here and in much of the US, you could say that conditions here can be considered extreme.... Long idle times, stop and go traffic, extreme heat, high humidity, dusty/polluted air, etc. 80k km in between ATF changes translates to about every 4 to 8 years.
    When I had my Civic, I change ATF every 3 years (or every 30k km), just for insurance. And on the 6th year, I also had the ATF filter replaced. ATF change is relatively cheap, if it means you're prolonging the life of the A/T.
    Dec 2009
    180,000 kms bago papalitan ATF... by that time putik na yan,
    thats almost 10 years na.
    Quote Originally Posted by miko101130 View Post
    There is a short statement on all owners manual which says "..whichever comes first"
    There are idiots who seem to disregard such.
    Mar 2004
    Philippine driving conditions would be considered as extreme driving conditions. There was a time when BMW touted their AT transmission as sealed type and no need for change ATF. After a few years, owners of the BMW models with supposedly sealed AT started having problems.
    Had atf dialysis on our 40kkm ride...
    I should say that I was not "proud" of the color of the atf....
    Oct 2015
    Anong brand po ng ATF ang ma recommend nyo? I have a Lancer MX 2004 and Altis 2009.
    Tumawag kasi ako sa Diamond motors it's Php582/L yung SPIII .
    Jul 2015
    Quote Originally Posted by BerrySnow View Post
    Mahal sa dealership.
    Im using Zic XPIII/SPIII for our fleet montero. If yan din rating ng lancer mo pwede yan. But sa altis hindi pwede.
    Jan 2011
    anong affordable na equivalent ng toyota t-iv atf? nakita ko yong apex na brand.. mura sa 299/liter.. any comments if equivalent ba talaga siya?
    Sent from my SM-G610Y using Tsikot Forums mobile app
    Jan 2008
    Quote Originally Posted by shelu View Post
    Why risk your transmission? Mura lang naman toyota atf.. almost 500 pesos per liter.
    apex brand? buy toyota sigurado tama ang formulation..
    Jan 2011
    thanks mga sirs. I was just looking for a cheaper alternative dahil may kalumaan na rin naman ang kotse. hirap din maghanap ng equivalent ng toyota T-IV atf. anyway, thanks. I'll stick with toyota atf.
    Sent from my SM-G610Y using Tapatalk
    Parang may nabasa ako dito sa tsikot, 400 pesos lang ang t-iv.
    Sent from my SM-T705 using Tsikot Forums mobile app
ATF change
