Page 156 of 167 FirstFirst ... 56106146152153154155156157158159160166 ... LastLast
Results 1,551 to 1,560 of 1667
    #1551
    Quote Originally Posted by Danilog View Post
    120 kph ba max speed na hindi huhulihin?
    Sent from my ONEPLUS A3003 using Tapatalk
    It seems to be the norm among those who frequent NLEX/SCTEX/TPLEX. Do anything faster and you might get tagged then apprehended at the toll gates.
    #1552
    Alam ako up to 110kph pero siguro sagad na dun yung 120kph. Huhulihin na pag nakitang mas mataas pa dun yung takbo.
    Jan 2018
    #1553
    Is that 120 kph on the speedometer or on a gps app? Minsan magkaiba reading sa akin
    #1554
    Quote Originally Posted by SpinCycle View Post
    Speedometers are not 100% accurate. They may be off by around 5%.
    Just doing 120kmh on the speedometer is fine on NLEX/SCTEX/TPLEX.
    Jun 2015
    #1555
    Depends on what size of tires the speedometer was calibrated to. Strangely, using the stock tires doesn't guarantee accuracy either.
    #1556
    Depends also on the tires you are running with.
    If you replace the stock tires with tires that have different size, diameter, specs, etc. then that will have influence in the reading of your actual speed on a highway.
    Dec 2017
    #1557
    Yup. Usual radar at Luisita.
    I've heard that there are devices that can detect speed traps. I wonder how much is it and where can you buy one.
    #1558
    The gps of the latest avt headunits found in many ppvs has a feature that can detect those speed radars when you're travelling there. It will warn you, saying 'there is a speed camera'.
    #1559
    Marami on Amazon for radar detectors, priced 5k and up. Unnecessary IMO - just turn Waze on, user reports already show you where the cameras are.
    I've been driving on NLEX/SCTEX/TPLEX regularly for several years now and the location of speed cameras haven't changed. Luisita for SCTEX northbound, Dinalupihan for SCTEX Subic-bound, Sta. Rita for NLEX southbound.
    The new additions are the fixed pole-mounted speed cameras in NLEX Mexico northbound and past the Bocaue tollbooth southbound.
    #1560
    By default, speedometer readings are about 5% faster than your true GPS speed if you have stock tires.
    My 120 kph speedometer reading is 114 kph on my GPS. Using 225/40R18 tires (roughly the same circumference as the stock 215/55R16).
    If you want your GPS and speedometer readings to match, use bigger tires.
NLEX, SCTEX, Over-Speeding, Speed-Radar  [MERGED Threads]
