Page 105 of 167 FirstFirst ... 55595101102103104105106107108109115155 ... LastLast
Results 1,041 to 1,050 of 1667
    #1041
    ^ dun sa building to the right of the back gate. was not a real seminar. halfway through the written exam (i was actually finished and had submitted my answer sheet already) they showed this video about lto, traffic rules, seat belt law, etc. the video lasted maybe 30 minutes. they did not even checked the exam, even allowed others to just copy the answer sheet of those who finished early or seat mates. inang yan, pinagisipan ko pa yung ibang questions kasi medyo vague yung choices tapos papakopya lang pala sa iba hahaha! buseeeet!
    Haha! Sana pala name mo na lang ang nilagay mo sa test sheet sir yebo. Sobrang hassle pala mahuli. 1 question just popped out of my head...yung scanner kaya nila regularly calibrated? (yearly) and how is it calibrated? Via gps speed or car speedometer reading? There is a bit difference between gps speed reading & car speedo reading
    Sent from my GT-P3100 using Tapatalk 2
    Nov 2012
    #1042
    Just use waze, updated na cya. Nandun lahat ng possible speed traps, it also warns you kapag malapit kna sa areas na yun especially if ur above 100kph, pag below it doesn't warn u anymore
    #1043
    Quote Originally Posted by Steveyemd View Post
    BTW, waze is only as good as the last updated info...
    Oct 2011
    #1044
    Quote Originally Posted by bobzy View Post
    car speedoemter reading is generellay calibrated higher than the gps reading unit.
    #1045
    ^ yes coz i noted that when speedo is reading *100 km/h....the gps reading is just around 90+
    Jul 2011
    #1046
    Hindi kaya pag nagpalit ka ng size ng gulong saka nagkakaroon ng discrepancies sa speed, kasi from OEM size pinaliit mo mas mabilis ang ikot, pag pinalaki mo mabagal ang ikot.
    #1047
    true yan. my speedometer was reading 135kph when i was clocked at 128kph. i also compared it with the gps, the gps reading is around 5kph lower than the speedo. same with my sorento, 5 kph lower din than the gps.
    #1048
    All brands calibrate the speedo higher. Some are more conservative than the others. With the two Corollas at home, my tires are slightly bigger:
    - On the 2007 Corolla, i changed from OEM 185/70R14 to OEM rims with 205/60R15 and now my speedo reading and GPS is almost spot-on (119kph GPS, 120kph speedo).
    - On the 2012 Corolla, we changed from 195/65R15 to 215/50R17 and the speedo reading is 118kph GPS versus 120kph speedo. Before that, the discrepancy was roughly 5-6kph.
    May 2011
    #1049
    +1 on me. Same discrepancy.
    I remember somewhere here Niky had a good explanation on the GPS receivers/processors (?) about the discrepancy we get from the GPS vs car speedo/gauge. ;)
    Feb 2012
    #1050
    I change my stock Altis 185/70/R14 tires din to 195/60/R15 which according sa tire calculator is just a 0.1% discrepancy. Using the GPS of my Lenovo phone, almost to the dial ang reading, e.g. a reading of 60kph on the GPS is also 60kph on the speedo dial. On my brother''s Civic, reading on the GPS is approx. 5kph lower than the speedo reading.
NLEX, SCTEX, Over-Speeding, Speed-Radar  [MERGED Threads]
