1.3J
1.3E
1.3G
1.5G
1.5 XX
1.5S
1.5SE
I don't own a VIOS.
Ok na Sir, nag pa change oil ako sa Petron, sobrang lapot na ng Machine Oilhindi na nalabas yung warning sign sa dashboard. P1,250 Change Oil Package
For the price yes...
Dapat Synthetic yung Package na pipiliin ko kasi yung ang ginagamit nung previous owner nung car, pero pag dating ko sa Petron sabi sakin mag Special na lang daw ako, kasi masyado daw malapot katagalan ang Synthetic. Any inputs po? kasi noob lang ako pag dating sa sasakyan
You should have went to shell. I just dont trust petron(lubricants)
As for the mechanic... he probably knows the sludging issues where old old oil will sludge hence his suggestion of mineral oil and more frequent oil change is necessary-avoiding sludge.
Good days mga paps! ask ko lang kung may nakaexperience na sa inyo magpaservice sa Toyota Plaridel, Bulacan area? May nakapagsabi kase sa aken na the best daw ang service nila doon. at kung may mairerefer kayo na service personnel doon. TIA!
hello guys, im planning to replace the suspension of my vios 2011 from stock. i find the ride unconfortable na dahil sobrang tagtag na at maalog. sobrang ramdam na rin ung vibrations sa loob due to uneven or gaspang of roads. this was also the suggestion of the mechanic that i talked to. now i'm asking if you can recommend for specific brands/models that would best fit especially for comfort. ok ba ung kyb? i heard ito daw usually gamit ng mga jap car vendors.
TIA!
Sent from my SM-A300F using Tapatalk
thanks monty, btw hm ung kyb for 1 set? ngpalit ka rin ba ng shock mounts?
Ngtanong ako kahapon dun sa service center na pinuntahan ko ang quote sakin 4300php x2 front, 2600php x2 rear tapos ung mounting is 1300php each. Di ko sure kung worth it na un or baka overpriced?
Yung sa gen1 vios, 2300 ang shocks sa harap x2
1200 naman ang shocks sa likod x2
Pareho KYB ang brand. Binili ko sa pasay taft. Tapos 750 ang shock mount.
meron po ba ditong naka experience ng parang rattling sound kapag humihinto ang sasayan... sa may bandang harapan... parang plastic lang ung tunog sobrang hina... pero nakakairita kc parang may loose bolt na hindi ko maintindihan... ung tunog nya ay parang sirang electric fan na tumutunog pag gumagalaw pakaliwa at pakanan... thanks in advance...
Sent from my HUAWEI KII-L22 using Tsikot Forums mobile app
When was the last nut and bolt tightening done? Model year of your vehicle? Brake shims maybe dislodge or a small stone is stuck on you brake caliper assembly...
May bayad ba pa-ECU scan sa casa? Pag nagtanong ako sa kanila palagi ang sagot diagnostic. Kaso may bayad.
Sent from my SM-J700H using Tapatalk
