Aftermarket madami. You just need a faceplate to cover the holes. Or you can look through forums for those na naka-upgrade na and want to dispose of their stock HUs.
1.3J
1.3E
1.3G
1.5G
1.5 XX
1.5S
1.5SE
I don't own a VIOS.
Sir chick, salamat sa pdf. Regards.
Sent from my GT-I9300 using Tsikot Forums Mobile App mobile app
that's what Im dreading, buti na lang someone offered to sell a stock HU. Funny thing just now, it's working again....
May OBD port ba ang VIOS and if yes, anyone here making use of it?
Mga Sir, para kasing tumutope ung auto ko on its 3rd gear sa 1st, 2nd & 4th okay naman usually sa 3rd ko siya naririnig. Nitro or xcs usually gamit ko na gas I interchanged it pero ganon pa din. Wala naman problem sa hatak malakas naman. I am suspecting sa oil kasi when I checked it lampas siya sa normal, does it make sense na oil kaya problem baka sobrang dami or any other things? Does anyone experience this? TIA
Sent from my HTC One X using Tapatalk
Light tope is normal. It's in the user manual. Kahit matic may tope at around 60kph. On my car it's more noticeable when I'm using XCS.
we have the same problem yung tipong at 3rd gear tapos papasok pa lang ng 2k rpm.
sabi sa akin ng SA Ricky Basto of Toyota Bicutan dinedescribe ko pa lang problem sabi niya hindi tope iyun and tope malakas. tipong parang tik-tik-tik tik na mabilis.
according to Ricky of Toyota Bicutan it is the cat.con. that is purging the carbon.
^sure kaya na catalytic bro kasi mejo malakas and coming from the engine eh.
Just thinking how about ung nagcacatless when replacing their muffler, does iy harm the engine kapag ganun set up kaya? Plan ko din kasi magpalit ng muff...
Sir yung catcon po after ng exhaust manifold, parang ang nadidinig mo sa gitna medyo baba ng gauge cluster. hehehe. muffler lang po daw ung nasa likod. sabi ni Sir Ricky, i also thought na ung catcon nasa may bandang muffler sa likod.
Ako nga sir nataranata minsa. nakakinta ako tapos mga 60kph ang takbo ko yung biglang nag--tiktititiktiktiktik ng mabilis. halos huminto ako sa skyway sa sobrang kaba. pero weird kasi nun nagrelease ako gn accelerator meron pa din onti. kaya satisfied naman ako sa explanation ng SA sa Toyota Bicutan na catcon un.
Still observing this on our Gen 1 Vios, but on our Jimny, nagkakatope pag Petron unleaded ang gas. Switched to Shell V-Power and the tope problem disappeared. Switched down from V-Power to FuelSave and the problem has not returned. Sayang, mura pa naman sa ofc pump station ang Petron fuel, pero no thanks na lang...
