Results 981 to 990 of 1447
- Jul 2016
- 17
July 23rd, 2016 06:13 AM #981Does anyone know kung saan pwede magpapalit ng lights ng instrument panel? Mahina na kasi yung sa Revo namen. Although minsan na lang gamitin, iba pa din na bright ang ilaw kasi minsan di ko na nakikita kung anong level na ng gas pag gabi. Preferrably para near south areas (Las Pinas) yung shops.
- 54,249
July 23rd, 2016 09:20 AM #982
- Apr 2008
- 6,235
July 23rd, 2016 09:29 AM #983Madali lang yan. They just open up the speedometer panel and replace the bulb. You can even have it replaced with LEDs if you want, for that optitron look. Mahirap talaga makita ang gauges natin sa gabi since the needles do not have backlighting...
Sent from my SM-G900I using Tapatalk
- Jun 2016
- 32
July 31st, 2016 02:06 PM #984mga sir ano po recommended nyo na engine oil, spark plugs, hi tension wires sa revo natin 1.8 gas m/t
- Nov 2008
- 641
August 1st, 2016 10:00 AM #985I've been using Valvoline XLD 20W-50 (mineral based only) for the longest time and its still good up to this date. I've tried the fully Synthetic blend and the improvement was not that significant. I've used both the NGK platinum and Denso Iridium, I'm now using the Iridium, but still there were no significant improvement in performance with the Iridium. I guess it would be the durability. I've changed my high tension wires to a Japan made (blue colored) tension wires (sorry I forgot the brand). Been using it for almost 3 years and so far it's still ok.
I guess our Revo's don't need those expensive PM supplies for it to run OK. Simple maintenance would do. Just do it regularly though.
- Jul 2016
- 3
August 1st, 2016 03:13 PM #986
- Jun 2016
- 32
August 3rd, 2016 10:55 AM #987Thanks for the input sir. sir pano naman malalaman kung nasa timing pa yung revo natin? kasi sabi ng mechanic self adjuster daw ang revo at hindi kelangan ituneup. so for maintenance ang pinaka tuneup ng revo is change oil, change oil filter, air filter, clean servo /intake etc. pati fuel filter pano machecheck kung palitin na?
- Aug 2012
- 2,767
August 3rd, 2016 11:18 AM #988
- Nov 2008
- 641
August 3rd, 2016 06:09 PM #989Yung self adjuster is sa Valve Tappet lang, Hydraulic na kasi yun kaya no need to adjust. Pero yung sa ignition timing pwede maadjust, although bihira lang naman ito ginagalaw, mas maganda kung matingnan na din, gamit ang timing light. Yung fuel filter located ito sa ilalim ng drivers side, bale steel casing sya kaya di mo makikita kung madumi na. Worst case kung barado na yun, e mawawalan ng power o pupugak na makina mo. Kung ako sayo, wag mo na hintayin yung signs na yun kasi masama sa makina, ako normally every year ako nagpapalit.
- Jul 2016
- 8
August 5th, 2016 01:06 PM #990Sir and mga gurus I've recently bought a vx200 2004 model. I have a question concerning 3. of above quote. Sa nabili ko kc always at start nasa 1300 rpm then pag nag init makina nasa 1000 rpm pag nag on na ng aircon 1300 goes down to 900 rpm at it remain there. Nag on nman yong thermostat ng A/C kc nag titick nman during use. Anu kaya ang problem if bumababa ang rpm during switch on ng a/C? Help naman po mga sirs. Thanx in advance.
No, but it was what sounded closest to Bill, bill. Ha ha ha!
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
