Results 991 to 1,000 of 1441
- Nov 2008
- 641
August 5th, 2016 04:07 PM #991Sir, honestly I am not familiar with your engine as what I currently have is the 7Ke only. Anyway, let me share my thoughts regarding this: The rise of the RPM during initial starts are normal, this is to help the engine warm-up faster. Mine starts at 1000 then drops to 750 when fully warmed. When the AC (compressor) is operational or engaged, the rpm goes up to 900. Though upon millisecond time of compressor switching, the rpm surges to 1000 then normalizes to 900. This action is normal as the engine absorbs the compressor resistance during engaging, thus the minimal lowering of the rpm. When the clutch disengages, it goes back to 750. I think your situation is normal. Though your idle is a bit high, which I believe can still be adjusted to at least 750 or 800 at least.
- Aug 2012
- 2,767
August 5th, 2016 07:35 PM #992Meron kami VX200. Tama lang operation ng engine mo. Tataas talaga RPM ng engine pag AC compressor on. Yung ECU na nagko-control dyan.
Normal idle speed for VX200 M/T is 800 RPM, and for VX200 A/T is 850 RPM. This is when engine at operating temperature and AC compressor off.
Medyo mataas yang idle speed mo na 1000 RPM.
Sent from my D5833 using Tapatalk
- Aug 2016
- 2
August 6th, 2016 09:09 AM #993Goodmorning po!
question naman po, i own a revo sr 2001 automatic model. ok naman ang sasakyan. kaso nung ni long drive, sabi sakin nung mekaniko, magpalit na daw ako ng automatic transmision fluid kasi hindi daw maganda ang hatak o ung takbo paakyat. all the rest daw ok naman. pasenxa na at wala akong masyadong alam sa ganito. anong atf o recommended brand ba dapat kong bilhin? at normally ba yun lang ung dapat kong palitan? pasenxa na guys wala din kasi akong manual ng revo. salamat sa advice at tulong!
- Aug 2012
- 2,767
August 6th, 2016 10:29 AM #994What is your email address? I have scan copy of owners manual.
You can use any Dexron III ATF from local stores or gas stations. If sa casa naman, you can buy Toyota ATF Type T-IV. P450 per 1 liter. You need 2.4 liters.
Other things na pwede palitan if overdue na: air filter, fuel filter, spark plugs, engine oil, oil filter, differential gear oil. Check PMS in owners manual.
Sent from my D5833 using TapatalkLast edited by red_one; August 6th, 2016 at 10:33 AM.
- Aug 2016
- 2
August 6th, 2016 12:06 PM #995
Super salamat red_one!!!! salamat!!! pasend naman sa email ko ung manual. ito, oliveoyl0119*gmail.com. thank you.
Another question, pasenxa na! ung sa change oil parang nabasa ko kasi before na pag old car naman hindi naman na ata recommended na mag fully syntethic pa ko sa oil, pwede na ba ung usual lang or regular oil lang na available sa Shell or petron na gas station?
- Aug 2012
- 2,767
August 6th, 2016 02:20 PM #996
- Aug 2012
- 2,767
- Jul 2016
- 8
August 7th, 2016 07:40 AM #998
- Aug 2012
- 2,767
August 7th, 2016 12:52 PM #999Idle speed is controlled by ECU. It is not adjustable. What you can do is to make sure that all sensors are working fine. Also clean the throttle body.
Power steering is additional load to engine. The ECU will increase the RPM to compensate. That is normal and nothing to do with wheel/tire size.
- Jul 2016
- 8
August 8th, 2016 07:18 PM #1000
Daming issue ng SU7:grin:
Xiaomi E-Car
