Results 511 to 515 of 515
- Feb 2014
- 2,555
May 5th, 2024 10:03 PM #512
r16c is a commercial tire, high load rating so stiff sidewall. matagtag
i don't like a/t tires they're almost useless. in fact there are super mild a/t tires that are practically highway tires mag R/T ka nalang they're a cross between m/t and a/t
but for a fwd car that's not going to offroad regularly you're probably better off w/ these:
- Jan 2007
- 2,253
May 5th, 2024 11:16 PM #513
I think the problem is A/T has been co-opted by some brands that aren't really A/T, so manufacturers of actual off-road tires needed to make new branding, hence R/T.
The Pirelli Scorpions being fitted on many new high-end SUVs have very mild tread pattern and depth that it might as well be H/T.
But there are some A/T tires that are legit useful on the trail. The likes of Falken AT3W or now the AT4W, BFG KO2 and KO3, etc.
- Jun 2011
- 1,103
May 6th, 2024 04:14 PM #514Salamat sa inputs. May nakita ako na Giti, same din yata ito sa GT na brand.
Overkill nga load rating ng r16c commercial tire. Ayos naman ang ride ng L300 FB na na drive ko dati. Sanay naman ang Raize sa 35psi kaya matigas din stock buti soft ang suspension. Weird tigngan ang pad attachment.
Buti sa BFG KO2 may 215/65r16 size. $$$ nga lang.
Sa Falken Wildpeak AT3W walang size.
Wildpeak Trail may size at stock.
( 215/65r16)
BFG KO2 - 16k
Falken Wildpeak Trail - 7.8k
Giti AT100 - 5k.
https://www.lazada.com.ph/products/b...111615454.html
https://www.lazada.com.ph/products/f...301576215.html
https://www.lazada.com.ph/products/g...694894339.html
- Jun 2011
- 1,103
May 6th, 2024 04:42 PM #515Ito unknown, pero may review sa Australia.
Roadcruza RA1100 - 4.7k
https://www.lazada.com.ph/products/r...51182689.html?
In our case, the thermostat was removed. But yes, if the thermostat is stuck open, it might show...
low idling during cold start
