Page 549 of 775 FirstFirst ... 449499539545546547548549550551552553559599649 ... LastLast
Results 10,961 to 10,980 of 15487
    Aug 2015
    #10961
    i suppose, just like any non-offroad vehicle when brought off-road.. nakaka-tanggal pasta..
    its only advantages over sedans in off-road, are its slightly higher ground clearance, and its torque-ier diesel engine.
    Nakakatangal pasta talaga e noh hahaha btw thanks
    #10962
    Quote Originally Posted by desertfox615 View Post
    Due for replacement na 4 shocks ko. Ok ba mag kyb or stick to orig?
    Front
    Orig 2.6k each
    Kyb. 2.2k each
    Rear
    Orig 800 each.
    Presyong toyorama banawe po iyan
    i tried the kyb.. yung puti.
    matigas... even after a few thousand km..
    you might want to gamble a bit more and get the more expensive (black?) ones.. it probably won't be as hard as the whites..
    or go oem (probably the best choice, and most expensive).
    good luck.
    #10963
    Front
    Orig 2.6k each
    Kyb. 2.2k each
    Rear
    Orig 800 each.
    Bro. At what interval are you replacing your front shocks?
    I replaced my rear shocks at 35kkm. There were traces of leak during the 30kkm pms....
    Front shocks still feel okay.... Am nearing 40kkm
    Jun 2009
    #10964
    The car has 60k km in it. Pag dumadaan sa humps parang di na maganda bounce ng likod. Sabi sa casa wala pa naman daw leak. Sign of old age lang daw. Pero am thinking about replacing it na kasabay ng 4 tires
    #10965
    the front was already dribbling when we replaced them at about 90K.
    my son, who had been driving her for the last 30K, wasn't complaining about it, until i got to drive it again,....
    Aug 2015
    #10966
    good day sir,need advise gusto ko ksi palitan nang tire s hulihan ksi may scratch na. pwede ho ba mapalitan khit dalawang tire lang ok p nman ho yong s unahan.. 39k ODO 3 years thanks
    Aug 2013
    #10967
    Quote Originally Posted by skylab View Post
    ok na ok lang yun sir.
    ganyan din ako. hindi ko kasi kayang bumili ng 1set agad kaya by pair ako kung magpalit. medyo mas cost effective siya sakin kesa sa irotate ko yung 4tires tapos 1set ang bibilhin.
    Jan 2009
    #10968
    30-40,000 km on average lang ba buhay ng Innova shock absorbers? I was thinking dapat mga 60+k, at least.
    I know it's apples and oranges pero just for argument's sake, Civic ko, 77k km (7.5 years) and it's still using the original shocks. To think na mas heavy duty yung sa Innova.
    #10969
    Quote Originally Posted by innova2013 View Post
    I am rubbing it differently, bro.
    I rotate my tyres regularly,- like now,- every year for the past 3 years.
    It looks like I will be replacing all (four) at my 45KKm....
    Hayyyzzzz....
    27.4K _/_/_/_/_/:burn:_/_/_/_/_/
    Aug 2013
    #10970
    Hayyyzzzz....
    yung sakin naman sir, halos 30k+ kms o parang every 2 years palit ng tires by pair
    so kung may new pair ako, yun yung ilalagay ko sa front, yung dating nasa front yung sa likod.
    300kms ang weekly travel ko.
    kapag umabot na sa wear warning sign ng gulong, nagpapalit na ako. medyo madalas kasi ako sa rough road na inclined dumadaan. (Hilux)
    napansin ko kapag tinaas yung load rating sa stock tires, mas matagal mapudpud yung gulong. yung dating naka lagay sa innova 94 (205/65r15), ngayon naka 101 load rating (235/50r18) ako, halos 2 years na na walang rotation, more or less 15% to 20% lang nabawas. nakaka 20k kms na din ako sa tire set na yun.
    May 2005
    #10971
    The stock Yokohama A spec on ours is still thick enough NOT to reach the wear line at 35K kms. But the outer thread patterns are slowly becoming slicks already.
    It has only been rotated at 10K, 25K, and 35K Kms.
    #10972
    I have the same scenario with our current original Yokohama tyres bro.....
    Kaya nakakatakot itakbo ng matulin sa C5 extension (maraming high speed twists and turns),- lalo na kung basa ang kalye...
    Aug 2010
    #10973
    More pics:
    EGR Valve / Intake Manifold side
    Exhaust Manifold side
    sir oj88 tnx sa info, matagal ko ng mag pa egr delete sa innova ko nag dadalawang isip lang ako kaya di natutuoy,
    ask ko lang sir may nag bago ba mula nun nag pa alis ka ng egr?
    may gain sa acceleration? sa fuel consumption?
    nag lagay ka pa ba sir oil catch can?
    tnx sir
    Aug 2013
    #10974
    ganyan din sakin, more than 5k kms pa lang. ang culprit, busted front shocks.
    walang leak pero iba na yung ride niya, lakas mag bottom.
    nung napalitan, wala ng ganyang problem.
    possibility lang naman, pero unang sasabihin sayo ng mga suspension shop, wala sa tama yung wheel alignment.
    #10975
    nagpalit din ako ng 2 front tires na stock this week lang. hinde ko pa napa check ang aligment kung positive ang camber. lumabas na kasi yung mga thread at delikado.
    Jan 2009
    #10976
    Quote Originally Posted by wakiki77 View Post
    tnx sir
    To be honest, I don't have much reference. It was barely 2 weeks old when I had this done. Di pa nga naubos yung first full tank ko eh. But from what I can tell, I don't feel any adverse effects.
    I don't plan to put an oil catch can. Since effectively wala nang EGR, wala nang hahalong usok sa oil galing PCV to form carbon deposits or soot sa intake. Kung meron man, I would like to think na minimal nalang. EGR blanking to me is one of the major contribution to promote engine reliability in the long run.
    Aug 2010
    #10977
    tnx sir, last question po, nakita ko sa olx yung nag kabit ng plates nyo, musta naman quality ng plates nya?
    tatagal kaya yung gasket na kasama sa plates?
    after makabit any maintenance na dapat gawin in the long run?
    salamat ulit sir sa info
    Jan 2009
    #10978
    They're install and forget. Makapal yung plate. Imthink they should last the life of the engine.
    Jan 2009
    #10979
    Goodbye Toyota-san!
    Hello Mr. Ken Wood. Welcome to your new home...
    Dec 2010
    #10980
    hi mga sir.. need help about my 2007 innova (VVTi manual transmission).. had an accident hung June 12, crashed sa isang concrete barrier sa BGC.. eventually umangat barrier and nabasag din ang windshield.. nagawa na siya and i'm using it already.. ang mga pinalitan radiator, condenser, hood, front bumper, new windshield, wiper motor assembly, and siyempre isang malupet na latero because the roof ng innova slightly na deform..
    my problem is that parang sira ang air vent.. smoke coming from labas pumapasok.. i'm not sure if this is really the problem, or if the fumes coming from the aircon or engine ang pumapasok sa cabin.. basta iba ang amoy, as if something is burning, or parang coming from the engine.. sa aircon kaya ang problem or sa air vent?
    what do you think should i do? and san ok patignan 'to? maraming salamat mga boss..
Toyota Innova Owners & Discussions [continued 3]
