Page 365 of 775 FirstFirst ... 265315355361362363364365366367368369375415465 ... LastLast
Results 7,281 to 7,300 of 15487
    Apr 2009
    #7281
    question po. Tapos na 3 years warranty ko sa Innova 2010. Dapat ba ituloy ko pa rin maintenance sa casa? Kung hindi, ano po yung general guide na dapat icheck/palitan periodically?
    Example:
    Change oil - every 10000kms (if fully synthetic)
    Change tires ?
    What else?
    Pasensya na, di talaga ako maalam sa kotse
    May 2005
    #7282
    Quote Originally Posted by rafaelz5 View Post
    Example:
    Change tires ?
    What else?
    If Fully Synthetic, Casa procedure is you need to change the oil filter every 5,000 Kms and oil top up.
    My advice is to continue your maintenance with the Toyota casa since its more convenient and you don't have to sweat too much on what to do and what to replace, like when you do things on your own. And the Casa also has all the necessary equipment needed. Some may argue that gasoline stations also have those equipment. Depending on the casa, I still find the casa to be better than gasoline stations (which are most often poorly equipped).
    You can consult the owner's manual where there is a chart that shows at certain time or mileage intervals of when to adjust or replace certain parts. This is a good guide to review every time the CASA for service. That way, the casa can't pull a fast one on you.
    Apr 2009
    #7283
    Thanks for the reminder, sometimes, I really don't know if the Casa can be trusted.
    May 2005
    #7284
    Before servicing, based on your current mileage, you can ask them for a job list on what they will be performing and a parts lists that needs replacing. Then you can use the chart from the owner's manual to compare to see for any inconsistencies.
    BTW, I also had my Toyota serviced "outside" after the warranty period. I just asked a "mechanic" to change the oil and filter. But recently, I went back to Casa (Otis) bec. they have the right equipment and more experienced (or used) for the particular service my vehicle needed.
    BTW, choose a Casa where you can watch your vehicle in person (not through CCTV).
    Apr 2009
    #7285
    BTW, I also serviced my Toyota after the warranty period. I just asked a "mechanic" to change the oil and filter. But recently, I went back to Casa (Otis) bec. they have the right equipment and more experienced (or used) for the particular service my vehicle needed.
    I find the BGC casa okay since you can watch from upstairs, though there is not a seat. Alright, will do my homework and read the manual.
    May 2005
    #7286
    I would pick a CASA that has service stations positioned in an accessible area. This would allow you to stand right beside the vehicle. This will also allow you to talk with the mechanic.
    Oct 2005
    #7287
    Quote Originally Posted by shibby75 View Post
    At least di pa tayo old model. . .
    Wag lang naka 2.5 d4d VNT yan, o kaya 2.7 dual vvti, madami ma tempt mag upgrade. :-)
    Sana nga tapos may 2.7L VVT-i na may M/T :D
    latest whole pic of the facelifted Innova.
    https://www.facebook.com/photo.php?f...type=1&theater
    May 2005
    #7288
    Quote Originally Posted by basti08 View Post
    The front grille appears ill-fitting. Toyota getting inspiration from Honda?
    The rear hatch decoration is really tacky.
    Oct 2011
    #7289
    Example:
    Change tires ?
    What else?
    Sir, kndly check your manual nandun lahat.
    Sep 2011
    #7290
    Example:
    Change tires ?
    What else?
    Imho , for me, Oo sir iba parin yung casa maintained . Kasi sa casa naka sched yung mga dapat palitan na pyesa , unlike sa mga talyer kung kelan lang masira dun lang papalitan :-)
    Sent from my GT-I9505 using Xparent Cyan Tapatalk 2
    #7291
    depende na rin sa SA at mechanic yan... ang ibang SA kasi at mechanic kahit may kakaibang tunog sasabihin NORMAL lang yan... pero pag nasira na saka aayusin.
    Oct 2011
    #7292
    ung reputable na talyer alam din nila yan pms ng toyota.
    Oct 2005
    #7293
    Yeah, that's a horrible facelift. I hope it never does reach us, like what happened with the 1st gen Avanza, was never facelifted locally.
    #7294
    Example:
    Change tires ?
    What else?
    Nasa manual din kung ano chinecheck o papalitan sa PMS schedule, kung may kilalang mahusay at mapagkatiwalaan na talyer ay doon ka na magpa PMS.
    Sent from my Nexus 7 using Tapatalk 2
    Feb 2013
    #7295
    Minsan lugi rin kasi magpalit ng piyesa based sa length of service na nakaindicate sa PMS, para nga pangloloko na minsan yung every 5 or 6 months change oil ka.
    Ang alam ko lang na dapat sundin sa PMS yung ibase sa time ay mga fluids, other than that, mileage dependent na. And kung tapos naman na sa warranty, yung palit oil mas maigi yung annual same rin sa ibang fluids.
    Oct 2011
    #7296
    ung change oil lalo na pag diesel highly recommended that you change it every 3-5k or 6 months lalo na if you are using ordinary minderal oil. anyway, subjective din naman kasi yan and ung pms in general nasa owner un kung ano susundin o hindi
    May 2007
    #7297
    Quote Originally Posted by hops View Post
    Ayaw gumana ng water sprayer sa windshield ng innova namin... Ano kaya problem? Anyone encountered the same defect?
    San ba dapat ipacheck ito...
    Dec 2007
    #7298
    Sure ka na hindi gumagana? Nalagyan mo na ng tubig? Casa pa rin kung may ganyang problema.
    Sent from my GT-N7100 using Tapatalk 4 Beta
    Jun 2006
    #7299
    Example
    At 40,000kms required to change brake fluids and all fluids like diff oil,tranny oil.
    Mekaniko-ok pa yan, ala problema, malinis pa at malakas preno
    Casa- kailangan paltan kasi hydroscopic ang brake fluid, baka makasira ang moisture sa abs at brake pistons
    Since technical ako, maniniwala ako sa casa.
    Dec 2007
    #7300
    Toyota Marikina's service bay is easily accessible for owners. I bought my Innova from them and continue to have it serviced there. Similar to what you mentioned, I make it a point to have a chat about what is going on or anything about vehicle maintenance, all the while observing how they do things. I find it satisfying to see what is being done even if it seems routine.
Toyota Innova Owners & Discussions [continued 3]
