Page 340 of 775 FirstFirst ... 240290330336337338339340341342343344350390440 ... LastLast
Results 6,781 to 6,800 of 15487
    Aug 2008
    #6781
    Denso din yung 2012 Innova G D4-D namin
    Oct 2011
    #6782
    ano ba mas matibay denso o sanden?
    #6783
    Quote Originally Posted by rme View Post
    oo nga sir may point ka dun, nangyare kasi sa dati namin adventure outside namin pinalagay nkailan palit kami ng actuators lagi sira,
    cobra lang daw kaya ibigay sakn na brand ... hmmmmm ok na kaya yun? toyota pasong tamo ang branch ok ba service dun?
    Innova E may Central Lock na sya (all doors equipped with orig actuator), alarm system na lng kulang at keyless entry possible na rin.
    Jul 2011
    #6784
    the sanden compressor installed on the 2011 G m/t have a TRSA11
    goggled sanden and the code seems to be a SCROLL TYPE as TRSA12 is a scroll type
    less moving parts to me is reliable, no piston, just have maintenance for the oil as any other compressor (idk how to do it )
    one thing I learned is if your car will not driven for weeks or months it is best to run the engine with A/C ON once in a while to moisturize the rubber seals.
    #6785
    just finished 45k PMS, they suggesting na pa reface na yung both front disc ng innova g a/t namin. nung nag pa 40k PMS kami yung right side pa lang.. now both na. walang mintis naman yung pms every 5k ng innova namin sa casa since binili namin ng brand new.. twice na din nagpalit ng brake pads within 45kms period. hindi yata magandang gamitin yung OEM brake pads.
    pwede ko kaya ipawarranty yung disc plate?
    Jun 2006
    #6786
    Mas malaks naman talaga sa brake pads ang automatic tranny, pero not to the point na 2x in 45thou kms. Im on my 33thou, i do the maintenance myself no, tapos na kasi warranty, pero makapal pa pads ko, harap at likod. 4x na ako naka baguio at once sa highest point benguet.
    Mine is a 2009 G m/t vvti with a denso a/c. What im about to replace are the tires, palitin na ang harap, tire rotation ko is every 5k. Malakas ako sa hulong kasi i only inflate the tires to 28psi only, for a better ride.
    Sep 2011
    #6787
    Good afternoon mga sir! I will get my innova e mt on monday ask nun dealer kung gusto ko palagay ng alarm ( wala pa pala yun e model) meron daw sila promo ngayon 8k alarm with back sensor? Mura na ba yun? 6 mos warraty daw un alarm?
    Pwede na yan sir. May kasama pa back up sensor. Ako sa casa rin nag pakabit cobra brand din. Peru alarm only walang promo na sensor..
    Worth it naman kahit mahal kasi hindi ka maG worry na void ang warranty ng innova mo ;-)
    Sent from my GT-I9300 using Tapatalk 4 Beta
    #6788
    Sa mga VVTI owners....meron bang nakalagay sa PMS or Manual kung kelan mag palit ng fuel filter?
    how about oxygen sensor? pwede ba itong linisan?
    Feb 2013
    #6789
    40k ang palit, sa pagkakaalam ko, self cleaning ang oxygen sensor, useless na linisan kasi sa exhaust yan nakakabit.
    Di critical ang pagpapalit ng fuel filter sa gas engine comapred sa diesel.
    Dec 2007
    #6790
    Quote Originally Posted by CeeGee View Post
    Hindi warrantable ang normal wear unless there is unusual problem like hyundai tucson and sta fes with warped rotor disc. It appears A/Ts have higher wear rate on brake system than the M/Ts. Regular PMs will not help your brake pad and rotor wear. If there really is a problem, it's probably the way you drive.
    Sent from my GT-N7100 using Tapatalk 4 Beta
    Aug 2010
    #6791
    how many here replaced their innova's stock headlight bulb with all weather/season bulbs?
    Questions:
    1. brand of the bulb you install?
    2. wattage?
    3. did you install relays?
    4. performance of all weather/season bulb?
    May 2012
    #6792
    guys got a problem innova E 2012 A/T
    ung break lights ko hindi umiilaw sa rear left, ngayon ko lang napansin pero kung naka lights on ako nailaw naman
    pag break lang talaga ang wala, mag pa PMS palang ako 10k isabay ko na,, nagtaka lang ako bat nagka ganito eh 1year palang pundido agad?
    #6793
    Quote Originally Posted by trucker111 View Post
    Questions:
    2. wattage?
    1. Philipps
    2. Same sa stock
    3. no
    Jun 2012
    #6794
    Quote Originally Posted by evincar View Post
    Check mo fuse mo sa fuse box. Nasa owners manual yung location ng fuse.
    Apr 2012
    #6795
    Questions:
    2. wattage?
    I'm using osram all season super 55/60w, did not install relays.
    My front wind shield has medium black tint, for me maganda yung yellow hue kasi may contrast than the stock bulbs.
    Oct 2011
    #6796
    Quote Originally Posted by kristine123 View Post
    afaik, every 80k for vvt-i ung sa d4-d ang walang nakalagay sa manual.
    Oct 2011
    #6797
    ung sa akin ganon din mas mabilis mapundi ung rear right na brakelight compared sa left.
    Dec 2009
    #6798
    Check mo bulb baka busted na yung para sa brake double contact kasi yan, yung isa para sa park light then yung isa para sa brake. Kung ok bulb ckeck mo stoplight switch baka sira na, kung ok switch fuse nsman check mo, kung ok lahat dalahin mo na sa electrcian.
    Oct 2008
    #6799
    Both are good. Both are using Japan technology.
    Even the popular European cars are using both brands.
    But I think Denso is more expensive if compared with the same specs.
    Correct me if I'm wrong.
    #6800
    Nakasabay ako kanina on the way to the office ng isang white Innova Diesel J - black door handles -(from Toyota Bicutan), wala pang plate number dito sa may East Service Rd.... umuusok na ang tambutso,- even on normal speed...
    19.9K:cheer:
Toyota Innova Owners & Discussions [continued 3]
