Hi gud am po. ask ko lang po kung naexperience nyo sa innova ung pag umaatras para syang nanginginig. Naka full left/right ung manibela. Ano kaya prob neto? Tsaka how much palit ng clutch kit at san mura bumili? Thanks po. More power po sa inyo.
D4D Innova 2009 po yung sa amin.
baka mali ang timpla ng clutch/gas mo sir kaya naginig habang reverse mode ka.
saw the new 2.5g metallic gray. baduy lang yung color ng interior.
gray ang labas tapos beige ang loob. mas ok sana kung gray or black.
Sir, paano ang step by step procedure cleaning the TB?
Di po ba masisira ang motor to manually open the butterfly? dapat po bang tanggalin pa battery? ilan na po ang odo nyo nong nilinisan nyo TB? marumi po ba? pag nasobrahan ng TB cleaner ok lang po ba?
Parang meron kasi akong naamoy sa exhaust na parang gas.
INNOVA VVTI AT 2005 with 70k odo
You can, manually open the butterfly and play with it pushing it open/close - it is spring loaded, that automatically position itself back.
To clean, just remove the air intake tube and spray some carb cleaner and let it soften the sludge for a few minutes, then finish it with generous amount of spray to drip off sludge. Put back the air intake pipe and start the engine. Ganito ginawa sa Innova ko ng nagpa-check ako sa isang kilalang shop dito sa tsikot, they also cleaned the MAF sensor with earosol electronic contact cleaner (spray-spray lang sa maf sensor without touching the electronics inside)
