Results 1 to 20 of 3899
    May 2005
    Just a tip for Innova, Fortuner, Hilux with non-VGT 2KD-FTV (no hoodscoop on bonnet) only. 1KD-FTV, i have not seen nor tried yet.
    Its possible to fit a bigger oil filter (ie. B2, LF3487, etc..). I asked the mechanic to try this. It fits or shoots right in. But you might have a hard time removing the filter later on your next oil change bec. there is little, to no wiggle room to maneuver. Of course take note he uses a chain to remove filter so that requires wiggle room. But if you have other method of removing the filter then using a bigger filter is possible.
    May 2009
    yan din ang naexperience ko sa innova. pero buti na lang mayron akong strap wrench na ganito: STANLEY | HAND TOOLS | Specialist Automotive Tools | Engine Service & Accessories | Economy Strap Oil Filter Wrench
    Mga Sir pa help naman po anu po bang fit na baldwin oil filter sa crosswind 2010 xti ko? ok lang po ba na fit ang thread at gasket kahit maliit ung size ng oil filter kasi ung b113 parang maliit, yung b166 naman iba ata ang thread and maliit din. sana po matulungan nyo ako. Maraming Salamat po.
    Oct 2004
    Share lang po...
    Oil filter for 2.5 years (7000+kms lang natakbo at that period). Two filters on remote filter relocation bracket. About the same lang ang loob ng filter nung binuksan ko using an oil filter cutter (isa lang ang na-picturan ko).
    Since the oil filters are mounted upside down in the relocator bracket, there is noticeable gunk that settled on the rear/bottom of the oil filter. Filter element condition is very good (no noticeable buildup of trapped dirt). The engine was essentially clean (4A-GE 16V 'red top').
    The Baldwin filters are well worth it.
Remote bypass oil filtration
