Results 14,861 to 14,870 of 15485
- Dec 2019
- 2,073
December 17th, 2021 12:56 PM #14861
December 17th, 2021 01:13 PM #14862
To those who have attempted to change their tires from 205/65R15 to 205/70R15, any apparent pros and cons doing so in terms of ride quality and drive performance?
I do know that it will affect the speedo, which the higher-profile tires will probably make it more accurate, in fact.
My tires are getting a little long in the tooth so I'm looking to change them out sometime next year.
December 17th, 2021 02:35 PM #14863
December 17th, 2021 03:04 PM #14864
December 17th, 2021 03:06 PM #14865
Maganda yung gear ratio ng Innova with the stock tires. I wouldn't mess with it. Went to Tagaytay Highlands with my cousin a looong time ago and hirap na hirap sya to keep up with me even with a much lighter load. Especially on the steep inclines. He had the 205/70r15's and I had stock tires on.
If you want better ride quality I'd get better same sized tires and shocks instead. Or consider 215/65r15 if available. Stick to tires with the same or close to the same load rating as OE. The ones marked commercial will ride a lot rougher (ex. 205/65r15c)Last edited by Wh1stl3r; December 17th, 2021 at 03:09 PM.
- Apr 2010
- 742
December 18th, 2021 08:36 PM #14866^maybe hindi ka naman niya hinahabol?
or sliding clutch, driver factor, etc.
ang laki kasi ng fender gap on the 1st gen kaya balak ko din palitan to 205/70, or get an OEM 16s set from the 2nd gen, or get 17s - in order of comfort
- Aug 2013
- 262
December 20th, 2021 07:45 AM #14867
December 20th, 2021 01:10 PM #14868
December 20th, 2021 06:58 PM #14869
- Jan 2013
- 686
December 29th, 2021 10:00 PM #14870Innova 2013 G AT 2.0 (gas) - had my ATF fluid drained and replaced with MAG1 ATF.. consumed 4L pero sobra sa guhit sa stick pag check ko.. ilang litro ba dapat ATF ng Innova gas? This is my second time to replace ATF *61K+ odo (first time was *32K+ ODO) nakalimutan ko kung ilang litro yung pagpalit ko sa casa nung una.. tamad ako magkalkal nung mga resibo.. thanks..
i confess, my seagull review is from internet literature. that so-called aircon issue is a...
BYD Seagull
