Page 1495 of 1549 FirstFirst ... 13951445148514911492149314941495149614971498149915051545 ... LastLast
Results 14,941 to 14,950 of 15485
    Jan 2009
    #14941
    Quote Originally Posted by Vann-O View Post
    Hi. Gusto ko sana magpalagay ng lock/unlock sound, ung simpleng beep lang. Does anyone here knows a shop?
    My unit is 2014 G M/T.
    If you have the factory alarm, it's possible to enable the answer-back feature.
    To ENABLE it, follow these steps carefully... they are time-bound.
    1. Unlock the vehicle using the remote and get in, leave the door open
    2. Insert and remove the key from the ignition TWICE
    3. Wait 5 seconds... then press and hold the UNLOCK button on the remote for 4-5 seconds, TWICE
    4. Close the door and you should see the turn signals blink (you're now in programming mode)
    5. Press Lock, Unlock, Lock, Lock, Unlock on the remote. You should see the turn signals blink (end of programming mode)
    You should now hear one beep for lock and two beeps for unlock
    To DISABLE answer-back, follow steps 1 to 4 then use step 5 below:
    5. Press Lock, Unlock, Lock, Unlock
    Aug 2013
    #14942
    I just tried this and didn't work
    Jun 2013
    #14943
    ako din :D 2019 innova G
    Jan 2009
    #14944
    Quote Originally Posted by Erick Chavez View Post
    The procedure is only for the 2015 and earlier (1st Gen) Innova.
    #14945
    look inside your engine bay, and see if you have a "loudspeaker" or extra horn in there.
    if you have one, then it's just a matter of finding out how to activate it. the casa workers probably know how to activate it. ask them, po.
    if you don't have one... it'd be difficult to make it generate a noise. you probably have to go to the aftermarket shops.
    aftermarket shops... they're the proverbial dime a dozen.
    taga-saan ba po kayo?
    i have a 1st gen G innova, with what i believe to be factory keyless.
    masubukan nga...
    Jan 2009
    #14946
    I made a video demonstrating how to enable and disable the answer-back feature.
    You've got to get the timing and procedure exactly right. If you missed a step, rushed it, or waited a second too long, then you'll have to start from the beginning.
    Again, this is only known to work on the 1st Gen. Innova (2015 and earlier) and only with the factory alarm. This will NOT work on 3rd-party alarms, even if they were installed by your Toyota dealer.
    My vehicle is a 2015 Innova G 2.5L Diesel. Disregard the appearance of my key fob... it's still the same factory remote inside.
    Feb 2019
    #14947
    Do you have a printed out procedure while doing this or this is just all in your head?
    Jan 2009
    #14948
    See post #14943 above.
    Did a few practice runs and eventually had it memorized. This topic came up several years ago and I even posted a video of someone else doing it, but that video has already been taken down.
    Feb 2019
    #14949
    Yes I have read the procedure you have written. But im asking if you memorize the whole thing while making the video? and are you using stock horn? it sounded different from mine.
    Jan 2009
    #14950
    Memorized, yes.
    What you hear is the single buzzer near the passenger-side fender (yellow).
    The main horns (dual-tone buzzers) are behind the front grille (orange).
Toyota Innova Owners & Discussions [continued 3]
