Page 1441 of 1538 FirstFirst ... 13411391143114371438143914401441144214431444144514511491 ... LastLast
Results 14,401 to 14,410 of 15375
    Feb 2019
    #14401
    I thought my H4 was just busted because it cannot go on hi-beam it turned out the H4 installed before is 80W I didnt it was 80W and the relay socket got busted I have to install a new wiring harness.
    #14402
    what got toasted?
    the relay, the bulb socket, or the long wiring?
    Feb 2019
    #14403
    what got toasted?
    The relay and the hi-beam socket of the bulb got toasted the electrician cannot find the negative wire so he recommend to change or buy a new harness.
    #14404
    perhaps if one removed the "humaharang na accessories", he will be able to trace it.
    i am assuming, the wires are color-coded...?
    if in doubt what color is which,
    consult the opposite headlight's wiring.
    i am also confident,
    that wiring info is available somewhere...
    Feb 2019
    #14405
    Is anyone using fuel injector cleaner? Is it the same as using 2T oil wherein you pour in the small bottle in your full fuel tank.
    #14406
    i have never felt the need for an injector cleaner.
    2005 D4d. 130+K km.
    ...am i missing something?
    Feb 2019
    #14407
    2005 D4d. 130+K km.
    Why are you not using it to clean your fuel injector because it is very much costly to replaced one.
    Feb 2019
    #14408
    One of my windshield washer nozzle is not working and upon inspection the hose was detached to the nozzle... I have a hard time connecting it under the car hood because of limited space have anyone tried connecting it how did you do it? Thank you.
    Sep 2019
    #14409
    how do you diagnose po a slipping clutch? kasi nagiging mataas na consumption ng innova 2015 diesel nag 7-8km/L sya sa city and mag 70,000 kms na rin kasi sya
    #14410
    Oh wow,- that's why we have to stick to the 55/60W bulb....
Toyota Innova Owners & Discussions [continued 3]
