Page 624 of 662 FirstFirst ... 524574614620621622623624625626627628634 ... LastLast
Results 12,461 to 12,480 of 13229
  1. #12461
    guys san pa ba pwede makabili ng full rear matt para sa innova natin?
    maliban sa banawe..
    badtrip kasi nung last palengke, tumapon ung katas ng pakwan, hehe
    Jun 2006
    #12462
    Quote Originally Posted by innoBOB[09JmtG] View Post
    maliban sa banawe..
    gamit ko sa likod full rear tray mat. hanggang sa ilalim ng 3rd rear seat ang coverage nya. natapunan na din ng palengke galing tagaytay, pero wipe off lang since hard plastic.
    kaso sa banawe ko din nabili. 1.7k
    Aug 2006
    #12463
    Quote Originally Posted by ArrJay0712 View Post
    BTW, mine is D4D. Below are the details:
    Total labour = 1148
    Fully synthetic oil (7 pcs) = 4305
    Oil filter = 425
    Tiptop = 1176 (Ano po ba to? Hinalo cya sa fuel)
    Under category P.O.L (what's POL?):
    Muti cleaner = 386.90
    Car care kit = 514.18
    Rag = 12.23
    Sandpaper = 18.33
    Are all of these necessary?
    Thanks for the advice.
    All those in red (P2K++) are questionable IMO, I never encountered them on my 3 years PMS with casa. You will need to verify those in red with your SA whether they are truly essential or not.
    Since you got Fully synthetic, on your 15K PMS it should be only 1 liter oil plus oil filter that should be billed. And tell your SA not to put any additives or flushing agents on your succeeding PMS.
    Natapos ang warranty period ko na walang additives or flushing because I always explicitly advise my SA not to.
    Mineral oil or synthetic?
    Done both during the warranty period and I find mineral oil to be more suitable since our car is private use and not PU's. Mineral oil engine oil change is every 5Kms while synthetic oil is every 10Kms (to make it seem acceptable due to high cost per liter). But would you believe that Royal Purple Oil which is a lot better oil than Toyota OEM synthetic oil is recommending 7.5Kms oil change interval max!
    If I have diesel engine I would still prefer 5kms oil change interval to make sure my engine internals is cleaned more frequent.
    #12464
    InnobOb
    Bord,wag muna lagyan.Panget tingan sa dashboard un. Makasira pa ng porma.Tint na lang kung gusto mo ng proteksyon sa araw. ok
    Drive safe!!!!
    #12465
    unga e, nag iisip pa ako kung kuha ako nito o huwag na
    salamat!
    wag na inno. papangit dash mo, although may purpose siya, mapupuno ng adhesive residue yung dash mo dahil nakadikit yan. So pag nilabhan mo o nilinis, tatanggalin mo then ikakabit then tatanggalin mo ulit. Papangit.
    Bili ka na lang ng dark tints sa mga mirrors sa gilid then medium sa likod at sa harap.
    pwede ka din bili sunshade.
    #12466
    InnobOb
    Drive safe!!!!
    #12467
    Quote Originally Posted by Mile2 View Post
    I totally agree on this;
    unless if you are using a Fully Synthetic Engine Oil and changes the oil also every 5km.... dont forget to change your filter every change of oil....
  8. #12468
    Anong details nyan?
    AFAIK, less than 4K for VVTI on fully synthetic and less than 5K for D4d.
    Check your service invoice for detailed parts and service fees.
    wah! napamahal pala ako sa toyota marikina? regular oil lang ako pero 5K flat pesos sa 10K PMS
    Quote Originally Posted by shibby75 View Post
    meron kasi ako nakita sa ebay pero di siya tray type, matt, meaning pwede ko i fold in case gamitin ko 3rd row, which madalas talaga gamitin, kung tray kasi di natutupi, unles
    may full tray matt na convertible to small tray para may tray ka pa din kahit na ibaba mo 3rd row seats, meron kayang ganun?
    Quote Originally Posted by morlack View Post
    InnobOb
    Drive safe!!!!
    yeap kinancel ko na order, hehe, brutal kasi init, tipid kasi sa parking libre, pag may bubong, mahal na bayad, tapos malayo din
    yeap thanks. may shdae naman ako pero sa extreme heat, parang di kinakaya, hehe
    butin nalang at umambon ngayong umaga!
    Sep 2009
    #12469
    Just talked to one of their employees, their SA is out for training kasi, yung tiptop daw ay fuel treatment daw for diesel engine. while yung multi cleaner ay yung iniispray sa brake pads for protection at yung car care kit ay inaapply daw sa mga door hinges. I think binayaran ko yung buong product kahit hindi nila naubos.
    * Sir Mile2: So yung suggestion nyo po for the 15k pms ay change oil to mineral oil? So, that would mean drain yung synthetic oil then add new 7 liters of mineral oil, tama po ba? magkano po yung mineral oil per liter?
    Thanks!
    Aug 2006
    #12470
    Thanks!
    NO, you already did Fully Synthetic on your 10Kms PMS and it is suppose to be good for another 10Kms, so on your next 15Kms PMS they will not drain all your oil rather they will just replace the oil filter and top it with just 1 liter oil. Therefore on your 15Kms PMS you will just pay 1 liter oil (P615) + oil filter (P425) + labor cost (1148) + miscellanous (rags/sandpaper) and without the unnecessary fuel additives and car car products. Your next 15Kms PMS should be in the range of P2400 only.
    You can switch back to mineral oil on your 20Kms PMS if you like or you can stick to fully synthetic, it is your preference.
    Cost per liter of mineral oil is less than P200 only. Actually Toyota mineral oil for gasoline at Toyota Makati is just P155/liter, so probably for diesel it is within that range also.
    These are the common practice of Toyota dealership with regards to oil change services:
    Fully synthetic - oil change is every 10Kms (but you will need to change oil filter + 1 liter oil for topping after 5kms)
    Semi synthetic - oil change is every 7.5Kms(but you will need to change oil filter + 1 liter oil for topping after 5kms)
    mineral - oil change is every 5Kms straight.
    Jul 2006
    #12471
    guys need your thoughts
    effective kaya itong dashboard protector,
    http://www.sulit.com.ph/index.php/vi...C+ETC%21%21%21
    planning to buy one, parking everyday under the sun.
    ano advice niyo?
    and up ko din ito from one thread
    good day to all!
    If your really want your dashboard protected without tinting, then you can try the dashboard leather wrap na ginagawa ng seatmate. I would think kaya ito sa innova. Bale wrap nila buong dashboard mo sa leather, mukhang maganda din based dun sa pictures na nakita ko sa website nila dati. Just an alternative and better looking than the one you are considering to buy.
    Jul 2006
    #12472
    Yung tray(wide) na nabibili sa Casa (di ko alam kung meron kamukha nito sa banawe), may butas na agad for the 3rd row seats lock, so di na kailangan alisin pag gamitin yng 3rd row.
    Kung mats naman, yung nabili ko sa ACE, parang 3m type sya, 5 piece set sya.2 sa front, 1 piece 2nd row (hangang sa ilalim ng first row seat mayroon sya), 1 piece sa 3rd row and 1 piece sa pinakalikod. Fit na sya and may butas narin sa provision for the seat locks. Kaya lang di ko alam kung nagbebenta sila para sa likod lang though, you can ask nalang.
    #12473
    Gud pm to all
    Ask ko lang this days pag on ko ng aircon ko.Ang buga niya amoy suka,di naman ganito dati.Pero after 1 minute ok naman sya wala na ung amoy suka.Baste every on ko ng aircon ngaun amoy suka siya,My ride is 4 mothns old na po.. Hoping for reply... Thanks
    Apr 2010
    #12475
    mag sir.. tulong naman.. ung aircon ko kasi minsan feeling ko malamig tapos minsan prang hindi ganun kalakas yung lamig.. parang feeling ko minsan hindi ata kumakarga ng maayos yung freon kaya siguro ganun... o kelangan na siguro linisan yung evaporator? kaso may nakita ako kanina innova parang tinanggal yung buong dashboard para lang maaccess yung evaporator siguro...
    new user of innova po ako. mine is a innova E 06. d4d.
    Dec 2009
    #12476
    Gud pm to all
    Ganyan din po yung innova ko dati pero sa simple advices po ni maam liv and mile2 ang cause nito ay molds dahil po sa humidity. Yung molds daw po ang cause ng foul smell. Contributing factor would be our climate po. Naging practice ko na po na i-on yung front and rear AC ng innova para ma-lessen po. Rear Ac po kahit naka-1 lang pwede na. Anyway, hindi naman siya makaka-affect sa fuel consumption ng sasakyan
    Dec 2009
    #12477
    Guys help po. We can't decide po kung sa casa or Shell station na lang kami magpapa-changeoil. 27kms na po yung innova. My mom said na sa Shell station na lang para makamura pero sabi ko sa casa kasi may concern ako sa sound every time na inaapakan yung clutch at para ask ko din about sa hindi pantay yung kain ng gulong sa right rear ng sasakyan. 2007 innova J vvt-i po.
    #12478
    Quote Originally Posted by 'innoBOB[09JmtG
    i think you can try using a Luggage Tray
    hindi sya natutupi coz it is made out of hard plastic, but it can totally fit at the back of your Innova, despite your using your 3rd Row Seat....
    and you can also buy this on any car shop, coz I got mine from KIDAUDIO and its a whole lot cheaper compared to casa....
    #12479
    Quote Originally Posted by pat_louie View Post
    since you got more than one inquiry, you can try to go to casa at first....
    Jan 2008
    #12480
    Hi.. I am a newbie here. we just got our innova G AT VVTI 2days ago. i just noticed yday na pag start ng vehicle parang nagrerevolution sya kusa. ganito ba talaga pag start ng engine? this is even w/o me stepping on the gas pedal. is this normal?
    i hope someone can enlighten me. TIA
Toyota Innova Owners & Discussions [ARCHIVED]
