Leak nga yan dre! At mukang galing sa joint. Ang problema pa, aluminum welded. Balik mo sa kasa bro. Mahahabol pa siguro sa hinang yan.
Kung Diesel yung Innova mo, might be attributed sa vibration ng engine.
If your Innova is under warranty, then you have the right to demand for a replacement of the tube assembly. Segmented naman siguro yan so they can replace a portion. Huwag ka magsettle sa hinang. It would appear to be different from my system's pipe arrangement. Gasoline ba ang engine ng ride mo?
gud day guys,.. i have the same routine with yellowjip... once 1month general cleaning yung car ko Innova G M/T variant kasama na engine wash sa mga carwash station.. but im pretty sure na pure water lang inispray nila sa engine coz i've asked the owner of the shop, just bought my innova last May'09.. safe ba ito sa engine... any ideas?????
Mga ka-innova, puro tag-ulan na naman ang hinaharap natin at malamang flooded areas. Saan ba nakalagay ang computer box ng innova? Sana may maka post para malaman natin ang itsura ng computer box.
Thanks.
one more question guys, have anaybody used an inverter sa innova? sa G variant kasi meron dun na plug ive ask some technician sa tabi-tabi na about the inverter pwede daw pero no detailed explanation.. anyhelp and detailed info on how this inverter works onboard.. para makagamit naman ng laptop while on travel...![]()
hi.. newbie here.. i have a 2007 innova dsl g m/t.. just this evening, i could not start the car. there was just a clicking sound when i try to start the engine. battery checked out ok (malakas pa ilaw at busina). i had asked help to jump start the car and it started. i brought it to a nearby vulcanizing/mechanic and he told me that it could be the starter relay. problem is, he too (and myself) could not locate it. i checked the fuse/relay box, and it is not there. any idea where it is? and is this really just a relay problem? any inputs appreciated. thanks.
Bro, did you tried to use a known good battery in replacement of your stock battery? If not, go and try replacing first the battery.
The tick-tick sound means your starter solenoid is working but the battery could not spin the starter. Your stock battery could have low current to start the engine.
Lights and horn is not a reliable signs of healthy battery.
