Page 18 of 81 FirstFirst ... 81415161718192021222868 ... LastLast
Results 341 to 360 of 1620
    Dec 2007
    #341
    Topgear article on Hilux.
    http://www.topgear.com.ph/feature/gin_is_green.html
    This particular vehicle picked up over 60hp and 80lbs (108nm) of torque using the alcohol injection on the Dyno.
    Jun 2005
    #342
    Good day guys! Im definitly planning to buy a 2.7 G gasoline fed this end of the month. It has been asked several times for a fuel consumption kms/li for this variant but I haven't read any reply yet. To owners pls post the actual or maybe average fuel consumption kms/li for 2.7G automatic gas fed variant. Thank you very much.
    Jun 2008
    #343
    Quote Originally Posted by juneljrGLS'05 View Post
    Hello,
    I hope this helps.
    The 2.7 variant of the Fortuner carries the same engine as the 2.7 variant of the Hilux. On motioncars.com, you may see that the observed fuel consumption of the 2.7G FORTUNER is around 7.2 to 7.3 km/L. Thus said, the Hilux's consumption may not be any different from that.
    Just an insight:
    The curb weight of the 2.7G Fortuner is 1,735 kg.
    The curb weight of the 2.7G Hilux is 1,670 kg.
    The difference is 65 kg or appx. 150 pounds.
    Therefore, the lighter Hilux "may" do better than the Fortuner's 7.3 km/L
    Jun 2008
    #344
    Hello,
    I hope this helps.
    Just an insight:
    May 2005
    #345
    For some reason, the rate from motioncars is a bit on the high side. They must have driven mostly in highways. 5.7 to 6.3 km/li is what I get with purely city driving on a Fortuner 2.7 VVT-i.
    Jun 2008
    #346
    Hello,
    Just a question number001: Is that what appears on your MID?
    Regards
    Jun 2008
    #347
    If it is not what appears on your MID, then it is more likely that motioncars did drive the test unit in a relatively light(er) traffic
    As for the 2.7 variant of the Hilux, I expect it to be consuming appx. 6.5 km/L -- provided that the fuel consumption number001 said is based from the MID.
    Jun 2005
    #348
    Quote Originally Posted by skaptew View Post
    here's my 2005 hilux j
    31x10.5x15 bridgestone a/t tires
    1 inch spacer lift sa front : 2 1/2" lift
    extended shackles sa likod : 1" lift
    how was the front lifted?
    how much did the lifting cost?
    please PM me address of the shop.
    TIA!
    Jun 2005
    #349
    just a reminder to all hilux (present model/vigo) owners.
    whenever you go for a wash (carwash shops), remind the attendants not to spray high pressure water directly to the wiper arm covers.
    my pair popped off and got broken (wiper arm nut caps) because of its brittleness.
    each cap will cost you 100 pesos.
    May 2005
    #350
    Quote Originally Posted by dedeypi View Post
    Hello,
    Regards
    No. I never consider the readings from the MID because of its inaccuracy (too optimistic). I compute based on total distance traveled and liters of gasoline consumed.
    Dec 2007
    #351
    san mura ang fender flare for hilux j/e?... salamat =)
    Feb 2006
    #352
    mga hilux vigo owners kelan tayo eb?
    Jun 2005
    #353
    puro busy yata?
    kaunti rin nag-po-post e.
    Feb 2006
    #354
    oo nga :tumbleweed:
    kulang tayo sa market
    #355
    hintayin nyo ko hehe....
    Jun 2005
    #356
    ano bang magandang day for EB?
    saturday siguro, afterlunch?
    saan? sa FORt?
    suggest kayo...
    Feb 2006
    #357
    pwede ren the fort
    marikina area naman ako eh.
    club name,something to think about..
    grupo hil-lux
    club hi-lux
    club mk6,mk5,mk4 etc.
    team vigo
    #358
    Hello,
    I hope this helps.
    Just an insight:
    i consider nyo din po ang aerodynamic drag ng bed ng hilux
    more drag = more resistance = increae in fc.
    #359
    mga bossing, kakasya ba 265 65 r17 sa hilux E?
    Jun 2005
    #360
    Quote Originally Posted by dieselNUBI View Post
    hilux E? hindi po yata. pero yung kay bilog 255/55/18 e. pwede mo naman ipa-try sa tire /wheel shop before you decide.
    bilog's hi-lux
Toyota Hilux Owners & Discussions [ARCHIVED]
