Page 19 of 81 FirstFirst ... 91516171819202122232969 ... LastLast
Results 361 to 380 of 1620
    Jun 2005
    #361
    Presenting, The Ultimate "Invincible HILUX"! TopGear's Arctic Truck
    Oct 2008
    #362
    i have a toyota hilux G 2008, its stock wheels are very slippery in wet conditions so im planning to upgrade the wheels as well as the mags to 20" series 50 will that compromise the riding comfort?coz 18" is barely seen so i prefer a 20".PLS ADVISE coz my dad told me its not a good idea but all of the tire dealers i went thru advsie me a 20" instead of 18"!!!
    Jun 2005
    #363
    Quote Originally Posted by binong View Post
    you compromise comfort whenever you upsize your wheels.
    but trucks were not made for comforts anyway.
    #364
    Atomictom, number001,
    My budget lift costs around 4k. This includes labor and alignment. All the materials used were from the junk shop (6” diameter steel pipe for the spacers and steel plates for the shackles).
    The lifting was done on our garage. As for the ride, I think it got stiffer.
    Sorry for the delayed reply
    Jun 2005
    #365
    Quote Originally Posted by skaptew View Post
    thank you for the reply sir.
    i wanted my hilux lifted the same way as yours.
    would you mind if ask for the phone number of the mechanics you hired?
    #366
    did anyone changed their stock shocks on their hilux G's to an aftermarket one?if ever my mga owners na nag palit na,may i know what brand/model did you install and how much.althought the stock OEM shocks are really tough also,i just want a softer ride,and at 130k plus on the odo,i think its time to change it already.
    thanks
    May 2008
    #367
    check nyo din bilstein shocks un gmit namin dads navara.ok po result
    Jan 2003
    #368
    Hi ! Just wanted to share my upgrade and experience with my 05 hilux 2.7L.
    Front : OME shocks/spring around 2.5" lift
    Rear : Bilstein shocks / 3 inch increase in shackles length (customized)
    Back Camera and 2 back sensors
    Tires : 32 X 11.5 X 15 AT BFG
    #369
    Quote Originally Posted by rvt View Post
    sir,
    why did you chose ome for the front and bilstein for the rear?why not ome or bilsteins for all 4 corners?
    Dec 2007
    #370
    Quote Originally Posted by nikko m View Post
    thanks
    sir ome shock and spring... kung may balak magpalit ng mga arb/steel type bumper for winch... use the heavy duty type spring tsaka yung nitrogen charge na shock.. sarap na ng ride nun..
    kung stock bumper, ok na yung light duty spring... yung sa rear naman.. shock lang pinalitan namin... dont expect too much.. leaf spring kasi e.. =)
    #371
    Quote Originally Posted by giboteman View Post
    no dont have plans on installing arb bumpers and changing the front coil springs,just the shocks,how much did you get your ome's?
    Jan 2003
    #372
    sir,
    I believe bilstein will last longer as the rear is loaded with heavy stuffs when going to province where the roads are rough and lots of ruts. Don't expect a car like ride, it is still a truck.
    Jun 2005
    #373
    sir, how much did you spend on the above upgrades?
    #374
    it is absolutely not a good idea, it only looks good but the ride is para kang nag gulong ng kahoy.
    #375
    my hilux E on 225 65 17 wheels
    Jun 2008
    #376
    Mga bro kung me kailgan kayo na shock mura from thailand gamit dito for hilux just PM me pwede ko padala diyan.
    *mods sorry po just want to help our bro's to get a murang parts.
    Feb 2006
    #377
    [SIZE="7"]set na naten ang team hi-lux!!! [/SIZE]
    Jun 2008
    #378
    *mods pasensiya na po ulit me introduce po ako na shock that increase the height 2" plus it is design for thai made trucks the name po is "AMADA Xtreme" also i will be introducing a piggy back system for diesel also from thailand will add Horse Power and Torque also alot more accessories for hi-lux, fortuner and strada.
    sorry po sa mods hindi po ako pag bebenta nag inform lang po na me bagong products na papasok diyan sa atin and hopefully mura siya pag binenta nag mga shop.
    Thank you po.
    Apr 2008
    #379
    hello po soon to be an owner of toyota hilux here!
    Jan 2003
    #380
    Quote Originally Posted by atomictom View Post
    I'm very sorry for a very late reply . . .
    The shocks and coils for the front cost P 22K
    The rear shocks P13K
    The customized shackles P5K
    The Camera and back sensor P5K, I have installed DVD wt LCD earlier.
    Each BFG 32" tires cost P8.7K
    These upgrades were done over several months, not a one time job.
Toyota Hilux Owners & Discussions [ARCHIVED]
