Page 70 of 179 FirstFirst ... 206066676869707172737480120170 ... LastLast
Results 1,381 to 1,400 of 3575
    Feb 2011
    #1381
    My 2011 Altis 1.6V had a knocking sound in front suspension both left and right when I'm driving on rough road ( at low speed, at approximately 5kph). I always complain to TOYOTA about the problem, they always told me to bring the unit to them (TQA) and I already lost count how many times I bring my unit to them (fixing the same problem). Sometimes the SA record my visit sometimes not but I'm sure they have the record of entry on the guard.
    There are times that they replace some parts like shock absorbers (nakita ko pinalitan nila), shock mounting, and some parts (i forgot the name) that are attached or included in the shock assembly. Most of the time they just re-tight and/or lubricate (that's what they said) The last time I visit (3 weeks ago) they told me they replaced the shock assembly but still the knocking sound is there. I also complain about "tok" sound when turning the wheels left and right, they said after lubrication the "tok" sound is eliminated but upon observation it is still there.
    I cannot understand why they can't fix it.
    Dec. 6, the service manager called me and advised that according to TOYOTA MOTOR PHILIPPINES the problem that occur on my Altis is normal that after a thousands of kilometer this knocking sound will appear (but the knocking sound appear in less than a month from the date of purchase, I bought my unit Dec. 2010). I was so shock and get angry after hearing that statement, I immediately advised the service manager that I want to talk to whoever from TOYOTA MOTOR PHILIPPINES release that statement and prepare a written statement on their claim. We have a meeting on Dec. 14, 2012.
    I hope TOYOTA MOTOR PHILIPPINES will act on the problem because this unit is still under warranty.
    If they don't act appropriately, they lost one customer!!! I WILL NOT BUY TOYOTA EVER!!
    #1382
    Quote Originally Posted by ian28 View Post
    I understand that frustration of having to spend time and money going back to the dealer with no results.
    You have the choice to go to another dealer and take a test drive with the SA to show the sound. TQA has been a dealer that has received several complaints already based on what i've read online so i wouldn't be surprised if they give you the go-around. On the Altis Club site, several complaints to suspension problems were repaired under warranty.
    I've been driving with my FC meter on for the last week and have been adjusting my driving style a little more. Based on the FC readings, keeping the car on higher gear always doesn't give me the best mileage returns as compared to keeping the car in a lower gears to get some engine braking and keep the engine in the proper RPM range, so i can go with the least pedal inputs (as in feather light pedal inputs). The MID on the E and G models only show one info at a time unlike the V model MID.
    #1383
    Try going to Toyota North Edsa-Balintawak, mas friendly mga tao dun.
    Sent from my GT-P7310 using Tapatalk 2
    #1384
    Dyan ako nagpapa-service now (5K and 10K PMS). I like the set-up of being able to watch my car upfront while it's being serviced.
    #1385
    Toyota Shaw and BGC also allows this. Gives you more peace of mind :D
    #1386
    However, based on the stories of Renzo, SG, and the others about BGC, i don't think we'll be watching our cars being worked on if we go there for PMS. :D
    Feb 2011
    #1387
    Thanks sa suggestions mga bro..
    Did anyone of you guys experience this kind of problem?
    Feb 2011
    #1388
    I had a similar experience of the knocking sound, especially with humps and bumpy roads. But this was only after i installed my set of TRD lowering springs from US and not with my stock set.
    Numerous adjustments, re installation, hose insulation didn't do the trick. It was only after we inspected the shock mount assembly and found out that the ring washer was too loose and not thick enough to give grip even when fully tightened.
    My mechanic even showed me that the shock assembly parts are not entirely from japan and the said part was made in china. I found that weird but didn't bother to post in other forums or report to toyota in my last pms.
    After we have replaced it with an after market type and installed on both sides, i never encountered the problem again.
    We even subjected the altis at various humps and bumpy roads with minimal braking, and there were no more annoying knocking sounds till now.
    TMP maybe right, that after a few thousand kilometers accrued, even the stock suspension and spring will somehow settle. This also the same principle if you put a lowering spring. And with that faulty ring, various users will eventually experience the knocking sound.
    Hope this helps.
    Nov 2011
    #1389
    Hi Guys,
    What are my options if I want to change the backlight color of my speedometer, etc (I don't know what its called btw. Sorry)? Looks pretty boring for me (orange). 2012 Altis 1.6G manual. I think for the V variant it is white? Thanks!
    Feb 2011
    #1390
    Quote Originally Posted by myCOROLLA_ALTIS View Post
    Hope this helps.
    Thanks to your inputs bro!
    #1391
    Hope this helps.
    Thanks for the info. Those small kalampag problems can be quite annoying and usually they're the hardest to pinpoint.
    Quote Originally Posted by kiamoyman View Post
    Hi Guys,
    Depends on the type of bulbs the cluster uses. If it's the peanut bulb type, you can try changing it to LED ones.I haven't seen an opened Gen 10 instrument cluster so i can't tell yet what exactly it uses.
    Feb 2011
    #1392
    Update:
    (Gist)
    They don't have the written statement because they said they are not informed, well, I expected it but they promise to provide it not later than thursday, Dec. 20. They promise to fix the problem since this unit is still under warranty (the personnel from TMP will personally handle it - that's what they said - I don't know if this true hindi ko naman makikita kung talagang personal sya magaasikaso). They are going to provide service unit while my unit is still under repair (at least pampalubag loob).
    #1393
    ^ this is still at TQA? At least they're providing you with a service vehicle.
    On the FC average with my MID, it registered 12.1km/l in my last fill up while my computation got me 11.45km/L; that makes for arough .6km/l discrepancy.
    Feb 2011
    #1394
    Yup, still at TQA.
    #1395
    Anyone know where I can get one of these silicone remote covers?
    Both sellers I've seen in Sulit don't have any stock. I'm pondering on just going straight to Banawe in the hopes of finding one.
    Jul 2004
    #1396
    Tried in banawe as well but they don't have stock either but that was a couple of months ago.
    #1397
    Quote Originally Posted by glntVR View Post
    Damn, that's sad. Thanks for the heads up though.
    But just in case, do you know of any shops in Banawe that I can call to ask for stocks? Kung wala talaga pupunta na rin ako and I'll scour through the entire length of the avenue to look for one.
    Nov 2011
    #1398
    Hi,
    What is(are) the best color(s) for seat cover of a medium silver 2012 Altis 1.6G and recommended shops as well?
    Thanks.
    Feb 2011
    #1399
    Hi,
    Thanks.
    If you don't have tint, it would be nice to have a dark contrast with the silver exterior. I'd go for black.
    I recommend seatmate. They're well verse with altis covers and of high quality.
    Nov 2011
    #1400
    Thanks myCOROLLA_ALTIS! My car is tinted but not to dark. I'll probably go for black. Any ideas on price range of seat covers? Already request quotation from seatmate.
Toyota Corolla 10th Generation Altis Owners [continued]
