Page 169 of 186 FirstFirst ... 69119159165166167168169170171172173179 ... LastLast
Results 3,361 to 3,380 of 3706
    Jun 2008
    #3361
    May lamat na siempre dapat palitan bago pa tuluyan maghiwalay at madamage ulit ang newly replaced support.
    Oct 2015
    #3362
    Quote Originally Posted by yellahfellah View Post
    A couple of days ago, I had our 2007 Avanza 1.5 GL AT checked out due to a knocking problem near or at the engine. My mechanic at Kitanlad (near Banawe) found that the Transmission support was already destroyed and meron na daw lamat yung right hand (RH) side na Engine support. He also found an oil leak at the Flywheel oil seal (at rear of engine daw). Due to the lack of time, only the Transmission support and Flywheel oil seal were replaced (with original parts c/o Toyorama).
    7 PM na ako umalis doon because coding yung car and when I finally left, I found out na hindi gumagana ang speedometer and the car wouldn't change gear (upshift). The following morning, this was promptly diagnosed as a faulty Speed sensor, as in naputol/nabiyak siya. Sensing that my mechanic and his boys were somehow responsible for this, I asked them to remedy the problem, which they eventually did by soldering wires to the 3 connectors to maintain the continuity (see pictures).
    Tanong ko lang po sa inyo:
    1. Do I need to have the Speed sensor replaced by a new one?
    Note: Wala naman akong napansin na problema with the said part for now, pero baka naman magluko in the future. As per Toyorama, original part lang ito and order basis pa, around P7K. As for surplus, meron daw mahahanap yung mechanic ko, baka daw mga P2,500.00.
    2. Do I still need to have the RH Engine support replaced:
    2.1 With original part for just the RH side, around P3K; plus labor, P???
    2.2 Or with replacement part for both sides na, P700 x 2; plus labor, P???
    Note: I noticed the disappearance of the knocking sound, but as per my mechanic meron nang lamat yung RH Engine support.
    Sana po ay matulungan ninyo ako at mabigyang linaw ang aking pinuproblema.
    We from Avanza Club Pilipinas Inc. been 9 years as club and understand the problem of our avanza. We have gurus and technical expert that will help to assist you. They are also owner of Avanza.
    Mr. Weng Tan of CAES at San Juan can help you or pm us (admin) in our fb group page : https://www.facebook.com/groups/avanzaclub.ph/
    Jan 2008
    #3363
    Quote Originally Posted by lady_fox2009 View Post
    Thanks po, Maam lady_fox2009
    Nag "Join" na po ako kanina, pero "Pending" pa po ang status ko sa FB Page ng Avanza Club Pilipinas...
    Also, to update everyone, I had the Engine supports (both LH & RH) replaced this afternoon, pero replacement parts lang. Total cost ko for this was P2,400.00 incl. labor. Yung original parts kasi is P6K for both LH & RH sa Toyorama, plus P1.2K for labor so almost P5K ang natipid ko.
    Yung Speed sensor naman ay pinag-iisipan ko pa kung anong gagawin. Mahal kasi ang original part (around P7K yata at Toyorama), pero mahirap naman makakita ng surplus for 1.5 GL AT model.
    Jun 2009
    #3364
    Accessories price list at Toyota BGC
    Dec 2015
    #3365
    Quote Originally Posted by anonemus View Post
    Is this only applicable to latest models of avanza? we owned first gen avanza j
    Jun 2009
    #3366
    Quote Originally Posted by Muvanza View Post
    Not sure. Toyota Global City's number is in the pic. You can call ☺
    Dec 2015
    #3367
    Noted Sir, thanks
    Aug 2015
    #3368
    Sir baka meron po binebenta jan Center console for Avanza Gen1.
    Dec 2015
    #3369
    mga sir ask ko lang ano na ba usually ginagawa o pinapalitan kapag ung mileage na ng avanza j is 132000 na? TIA
    #3370
    Hi I'm back again in this forum. Also an owner of Avanza 2009 1.5G AT. Pending pa po un sa FB paki confirm nyo nalang po Eec ang name medyo mataas lang ang setting ng privacy ko kaya ganun lang name ha pero hindi troll account yun.
    Anyway magtatanong narin po ako medyo mahaba na ang thread na ito kaya di na ako maka pag back read. Meron bang available na hitch para sa avanza ko? Saan nakakabili at ano ba ang tow capacity ng avanza 1.5G AT?
    #3371
    Quote Originally Posted by eryxon View Post
    my first question would be, "is it safe for an avanza to pull a considerable load? does it have a tow capacity at all? it seems... so light...!
    i ask because i know not the answer.
    #3372
    I think its safe. Basta within its capacity.
    #3373
    i did a quick google. a dealer in sough africa says the avanza has a 500 kg towing capacity (unbraked trailer).
    #3374
    Thanks. OK na ang 500kg madami ng pwedeng hilahin.
    Meron ba sa pinas na available hitch bar? Search ako pero puro hilux at mga SUV nakikita ko.
    #3375
    i haven't seen an avanza pulling anything besides smoke.. heh heh.
    you will probably have to look for someone who custom-makes them.
    many years ago, i came across this guy who did make custom-make hitch bars... taga-bulacan... forgot the details. sorry.
    but i can imagine.. it might be "difficult" to open the rear hatch, if the avanza were hitched to something...
    Mar 2016
    #3376
    Sir Ask ko lang kung worth it ba mag add ng 100k for the Avanza 2016 1.5G variant
    or okay na rin ung Avanza 2016 1.3E variant. Mainly city driving lang ang purpose and balak dalhin sa baguio rin ocassionally.
    Thanks
    #3377
    Quote Originally Posted by bremensleash View Post
    Thanks
    i'm ok with the E.
    what does the 100K give you, po?
    #3378
    Thanks
    Sa akin is 2009 1.5G pero worth naman ang idadagdag mong 100k kung sa power lang at kung for keeps na avanza mo.
    Compare ko ang 1.3 sa 1.5 Malaki ang difference sa power at syempre iba ang G sa E kung baga why settle for less if you can afford naman. Unless if you are considering the budget you have to think very wisely and do the side by side checklist.
    Mar 2016
    #3379
    Mga sir newbie here, I got 2016 1.5g at at sabi navi ready hu, paano po gawin para magamit navigation?
    Jan 2014
    #3380
    Quote Originally Posted by sinjr View Post
    You need to get an SD card to activate the navigation feature. Curious lang ako, kumusta ang konsumo ng 1.5 at with dual vvt? Di naman ba bitin sa paahon?
Toyota Avanza Owners & Discussions [continued]
